Thinking of going to 0/1 ga wire... need input
Old Jan 11, 2008 | 07:22 PM
dbleon's Avatar
dbleon is an unknown quantity at this point
Default Thinking of going to 0/1 ga wire... need input
I will be runningthis http://www.planetaudiousa.com/main/497for mykappaspeakers,and this http://www.planetaudiousa.com/main/484 to (2) 10" infinity kappa perfects.....
Right now my '89 blazer is wired with good quality 4 ga from a previous system. Should I keep it and run (2) 8 ga off a dist block to the amps, or swap out for 0/1 ga and run (2) 4 ga to the amps from a dist. block? Thanks all!
Daniel
Old Jan 11, 2008 | 07:38 PM
cloak01ls's Avatar
cloak01ls is an unknown quantity at this point
Default RE: Thinking of going to 0/1 ga wire... need input
I would definately go with 1/0 into two 4awg...You wight want to thing of doing your Big 3 as well so you dont run into dimming issues...
Old Jan 11, 2008 | 07:39 PM
Blazin_Jason's Avatar
I would run 1/0 for sure. Option 1 being the 1/0 with the dist block to both amps. Option 2 which I would do, run 1/0 and keep the 4g there as well. Why not you already own it and have it ran.
Old Jan 11, 2008 | 07:54 PM
dbleon's Avatar
Thanks guys! Im just finishing a custom box for the 10's... I'll post up some pics when its all done.
Old Jan 11, 2008 | 07:58 PM
bobditts's Avatar
bobditts is an unknown quantity at this point
run your 1/0ga to a distro block, 4ga to your mono amp and 8ga to your 4ch amp. anything else is overkill and completely unnecessary.
Old Jan 11, 2008 | 09:52 PM
dbleon's Avatar
where can I find some good 0/1 wire. Ive heard knuconcepts is good... any advice?
Old Jan 11, 2008 | 10:01 PM
cloak01ls's Avatar
knukoncepts is good, i order most of my kits for customers from them...You can find Kicker kits on ebay for pretty good prices as well...
knukonceptz is the name, I use there products and they are nice. Lots of people use them. Can't recall hearing anything negative ever.
Old Jan 11, 2008 | 10:03 PM
cloak01ls's Avatar
ORIGINAL: Blazin_Jason
If I had one thing negative to say about them is that the install accessories they supply with thier kits is junk. The Zip Ties, Connectors, Grommets. I really have to use my own to not get frustrated...
Old Jan 11, 2008 | 10:13 PM
I just ordered another 30 of their 1/0 ring terminals, what connectors are you referring to? Never used their other accessoires you mentioned. I've used their RCA's, speaker wire, power wire, fuse holders, and a couple amp kits.
