uh o heres number 3... got problem with the subs
Old Feb 17, 2008 | 11:09 PM
madeforliving's Avatar
madeforliving is an unknown quantity at this point
Default uh o heres number 3... got problem with the subs
i have never had this much trouble with an install before, i dont know whats going on but i finally got everything (well almost everything) working today the only real problem i ran into was the amp wont turn on when my head unit is in CD mode. It works perfectly with the radio though. Could this be something to do with the ignition wire? have i forgetten something? The head unit is a Kenwood KDC-319. I know its old but it still shouldnt give me these problems. should i just try another head unit?
Old Feb 17, 2008 | 11:12 PM
cloak01ls's Avatar
cloak01ls is an unknown quantity at this point
Default RE: uh o heres number 3... got problem with the subs
Easy solution, this happens all the time. Sounds like you hooked up your remote turn-on wire for your ampto the Power Antenna wire instead of the Remote wire. Theyre both blue, but one has a white stripe(I forget which one)...
Old Feb 17, 2008 | 11:15 PM
thanks! ill see if it works. i really didnt want to have to change out the head unit. thats always a pain in blazers....
Old Feb 18, 2008 | 12:47 AM
felonyblazer96's Avatar
felonyblazer96 is an unknown quantity at this point
its just a simple wire error i make them more than id like!
Old Feb 18, 2008 | 08:24 AM
bobditts's Avatar
bobditts is an unknown quantity at this point
Yep yep. These guys nailed it on the head. you wired your remote turn on to the power antenna. The power antenna wire is only supplied power when your radio is on.
ChevyHick01
Jun 18, 2011 06:27 AM
Chadoo951
Oct 26, 2009 10:22 PM
RolingKCBlazer
Aug 9, 2009 08:06 PM
HoT92Blazer
Jun 8, 2009 02:35 AM
RolingKCBlazer
Sep 3, 2008 08:32 PM
