Upgrade Incoming!
Well I'm getting rid of my newest system! sadly ive only had it for like uh 5 months? lol. But I am upgrading to 6 Kicker Comp VR's dual 4 ohms. Sorry I didnt get it metered guys
I will also be building a new Ported box for these subs so i get more spl out of this. I will post a work log once i order the subs and all.
Selling it locally. Sold em all in like 5 hours of being on the market! lol.
But Selling the 6 comp C12's and keeping the amp. Planning on getting another A1800DB amp and building a ported box so i can hit the loooowwwww notes lol.
hahaa... nice. i havent even touched on the system yet. First a couple of mechanical issues... a squeak I just HAVE to find and some pins/bushings in the driver's door hinge... then I'm getting an alarm. This alarm will blow away anything I've ever had. It has an entire panel on the remote. It will tell you the temp. in the car and roll the windows down for you, remote starter, beep to alert you that your alarm is going off for you to shut it. You can put it on "warm" and if you are going to be gone for lets say an hour but you want to keep the truck warmed up... it'll turn it on and off in intervals that you set (I probably wont use this feature).
THEN I'll work on a system... I refuse to put anything expensive inside the truck before giving it a little security.
ORIGINAL: Dory
so your wanting to port 6 CVRs?
12s or 10s?
because ported, about the smallest box you could do that would be worth while is around 10cuft
its better to do less subs in the right airspace, than more in cramped airspace
a 10 cuft box will take up the whole back end and be taller the back seat
and if your going to get another 1800, you will need either some more batts or atleast a 200a alt or so, i suggest both
i have 2 A3000s in mine, on a 18MT, but im doing 2 15s next week, i already have one now and im reconing the 18 to a 15
12s or 10s?
