RE: UPS guy loves me
Man tell me about it! I'm proud for ya dude!
Well I finished the box and am still running the wire. Gotta take out the front seats tomorrow so I can get the 1/0 to fit. Can't just run it down by the sill plates like I thought.
edit. Here's the box, turned out pretty good I think. It's about 4 cubes after disc @ 33Hz. http://www.blazinjason.com/fibox2.jpg |
You're sub is in the box upside down! lol
Unless you're installing it sub up, ports back... |
ORIGINAL: drperry You're sub is in the box upside down! lol Unless you're installing it sub up, ports back... |
damn, good work bro.
wish I could build box's |
ORIGINAL: blazinloud damn, good work bro. wish I could build box's |
This is where it stands currently. List of what I still have to do is:
1. Do big 3 upgrade 2. Either upgrade the stock batt, or add one 3. Install 4002 comp amp 4. Install 6.5" components, probably in the stock door locations 5. Build a false floor and mount the amps flushmounted, will hide all the wiring 6. Fix wiring job on the box The speaker wire on the left has been ran to the front doors. 4g ran for the component amp. Everything is there for the amp wiring, so just needs to be hooked up. http://www.blazinjason.com/jimmy6.jpg http://www.blazinjason.com/jimmy5.jpg |
your running both amps off the stock alt?
ORIGINAL: blazinloud your running both amps off the stock alt? |
ORIGINAL: Blazin_Jason ORIGINAL: blazinloud your running both amps off the stock alt? |
