Using the brake causes the radio to turn off?
Old May 22, 2010 | 11:45 PM
drshay5's Avatar
drshay5 is on a distinguished road
Default Using the brake causes the radio to turn off?
I got this 95 Blazer LT from an auto auction. It did not have a radio, so I picked up an after market head and installed it using a wiring harness. However, whenever I brake suddenly, the radio turns off and then turns back on. I also noticed that when I brake, any dask lights dim and then brighten back up after I take my foot off the brake. I double checked the wires and all the connections I made between the head unit's wiring harness and the aftermarket one that the stock plugs will plug into. Any thoughts? Thanks!
Old May 22, 2010 | 11:47 PM
BlazerGuy2001's Avatar
uhh yea thats a really bizarre problem, it sounds like the brake pump is drawing too much voltage and is just causing a lack of voltage to everything else...have you replaced the battery yet? maybe its going bad?
Old May 23, 2010 | 06:27 PM
drshay5's Avatar
Yeah, I just got a new battery... but it's interesting... I'm looking at the gauge cluster and voltmeter states the battery is pushing about 9 volts after I installed a brand new battery.
Old May 23, 2010 | 06:44 PM
MTopper's Avatar
9 volts before you turn the truck on or while the motor is running?
Old May 23, 2010 | 10:42 PM
drshay5's Avatar
While the engine is running... And it's alittle bit above the red box right after 9 volts...
Old May 23, 2010 | 11:50 PM
yea ummm thats wayyyyy too low for running voltage, mine runs at just around 14volts with a normal alternator and same as stock battery
Old May 23, 2010 | 11:56 PM
MTopper's Avatar
Check your alternator. it could be that its not charging the system right, it could be a lot of things but the battery and alternator are 2 things i also check first and second
Old May 25, 2010 | 10:12 AM
drshay5's Avatar
I did a load test on the alternator yesterday. It showed the correct volts and amps. Any other thoughts?
Old May 25, 2010 | 10:58 AM
84BlazerS10's Avatar
My car did something similar for a while after installing a stero. But, mine would do it when putting on the brakes to shift from reverse to drive. It went away after I installed a new battery. Very weird though and still don't understand what caused it.
Old May 26, 2010 | 08:42 AM
drshay5's Avatar
I've already installed a new battery though..
