VSS - Vehicle Speed Sense Wire HELP??
Old Jan 2, 2007 | 10:53 PM
wolv2401's Avatar
wolv2401 is an unknown quantity at this point
Default VSS - Vehicle Speed Sense Wire HELP??
Would anyone happen to know what and where the speed sense wire would be on my 1998 Chevy Blazer 4 door with a 4.3L Vortec engine? I have a Pioneer Avic-N2 installed and I want it to be a little more accurate. If anyone knows what this wire would be or a site to tell me, I would really appreciate it.
Thanks in advance.
Old Jan 2, 2007 | 11:01 PM
hillbillyinOhio's Avatar
Default RE: VSS - Vehicle Speed Sense Wire HELP??
drivers kick, cruise control module. pin K. Dark Green/white. AC voltage. 4400 pulses per minute
Old Jan 2, 2007 | 11:24 PM
wolv2401's Avatar
Awesome, thanks a bunch.
Old Jan 3, 2007 | 12:06 AM
wolv2401's Avatar
Another thing, Directechs said the Tach wire was a white wire found in a red plug in a module inside the passenger fender area under the hood. However, I don't believe this is correct because that module does not have a red module. I was wondering if you knew of anything different than what directechs has.
Thanks again.
Old Jan 3, 2007 | 01:59 AM
grab the white at any of the coils. remem its ac as well when you are metering it
Old Jan 3, 2007 | 05:02 AM
amandocope's Avatar
amandocope is an unknown quantity at this point
would the vss be found in the same spot for a 2002 2dr?
Old Jan 3, 2007 | 09:29 AM
no, on 2002, its in engine compartment, drivers side, same color wire
Old Jan 3, 2007 | 05:36 PM
amandocope's Avatar
Rats. I was afraid of hearing that!
Old Jan 6, 2007 | 04:26 AM
Hanr3's Avatar
The vehicle speed sensor is in the tranny tailhousing (2 wheel drive) or in the transefer case (4 wheel drive).Follow the wire and see where it goes.
blazatronxprime
16
Sep 13, 2014 02:10 PM
raging56
Mar 14, 2014 04:30 PM
poertsch
Performance & Brainstorming
Mar 4, 2014 04:53 PM
pettyfog
Apr 29, 2013 12:55 PM
svd85
Nov 28, 2009 09:10 AM
