wanting to get remote start.. help..
im wanting remote start but would like to keep the factory key fobs... so im need one to hook to the factory keyless system.. i have a 1996 zr2, so i dont have the gm passlock system... any ideas, thanks...
i found this one on ebay i really like but the guy said it would not fit... Ebay Link fixed your long link - hillbilly |
RE: wanting to get remote start.. help..
Is there a black square piece with a strip of metal on it in your ignition key?
a 96 blazer does not have passlock. did not come standard until 1998 on blazers. I cant pull up that ebay link right now, but i install these for a living. most units that are an add on to the factory key fob lack seriously in the range of transmitters. most times you can get a nicer unit that will also do locks and hatch release for pretty cheap.
I was under the impression that Passlock II is standard on 98 - 05 Blazers and 95-97have Passlock I. At least that's what I gather from the Blazers that have come into my shop. I've done a remote start in a 96 or 97 before and it did have Passlock I.
in all my years of installing (12+) including putting a remote start on my fully loaded 97 blazer and my fathers matching 96, no passlock on a blazer from 95-97. some first gens had, some not.
this unit is tens times better than the one you found, and about the same price!! AviStart 4100 |
cool thanks,,, i think i will get it.... the only thing, will i have a button on the fob for the rear hatch pop function, thanks..
also look at this one i think it is the same one just a lil cheaper, but the key fobs look diff... thanks again.. Avital 4100 on ebay fixed your long link - hillbilly pm me on how to do this |
yes, you will. PM me if you need help installing the unit. I put that unit in my 97 blazer (b4 i sold it)
Im think of doing the same thing to my 05 blazer any difference then the 97?
yes, you will need a bypass for the passlock system. i would suggest the GMBP, PLJX or the 556L
HillBilly: I have a 98 LS Blazer but donot think I have passlock as there is not a strip on my key. Would it be alright to get one of the systems above. Which of the two avital systems did you get and how well did it work?
