Whole system is installed...but problems!!!
ya, get pat tanked, thats cash well spent over a cap.....
recently i turned all my bass boost settings down, way down, along with the eq(low,mid,high)
now im able to turn my hu volume up to about 95% without distortion. sounds alot better, cleaner, and clearer. I suggest you try this out.
So back to my main question. How do I make it so I can play DVDs through my DVD HU while not having to put the parking brake on. There is a wire coming out of the HU that says Parking labled on it attached to another wire coming up from near my parking brake. What do I need to do to disable it, simply unpluging the two wires doesnt help.
ORIGINAL: nofear17bmx
i think everybody has covered the gain issue and the cap debate, as far as your dvd player only working w/ brake engaged, thats a law that an installer has to hook it up like that so you cant watch it while driving, although you can bypass it but dont just cut the wire, it wont work at all then you have to hook it up to something to give it signal to trigger it , when i installed my dvd player i wired my wire into my fog light switch so if i want to watch it i just turn on my fog lights. but if a cop checks to see if it hooked up properly it will show the screen saying its unlawful to watch while driving as long as my fog lights are off. i am pretty sure that will work on any model
Ok. So I have to hook it up to a toggle switch? Do I have to give it power like if I were hooking up fog lights? That one wire coming from the HU would that be my ground or positive on the switch?
you take a toggle switch and put it inline on the parking wire to the ground wire. basically, you are connecting the brake wire to the ground, with a toggle switch on it.
Take the parking brake wire off the head unit and send it to ground with a switch in-line for an interruption. You do not need power going to this switch it is only a toggle to make a ground signal appear...
So then whats the difference between doing that and just taking the parking wire off the hu and just grounding it? I tried that and didnt work either.
