Wire path? for subs..
Old Jan 19, 2010 | 04:13 PM
DevinIsPro's Avatar
DevinIsPro is on a distinguished road
Default Wire path? for subs..
okay all i need to know is i have a 1997 blazer but i have no idea were i should run the wire for the amp from the battery to get in to the actual car i had it going like just bearly under the hood into the door but that bent and broke from the door is there any holes i am missing that will work? thanks i want to (bump)
Old Jan 19, 2010 | 04:24 PM
1987blazers15's Avatar
1987blazers15 is on a distinguished road
i had a 1998 but now a 1987. the holes are in the same spot lol. pull back the passenger carpet in the corner and you will see a rubber gromet on the firewall. pull out the grommet and drill a hole in it, thread your sub wire through and bam! here comes the bass
Old Jan 19, 2010 | 04:30 PM
Unlimitedsp's Avatar
There should be a big rubber grommet on the drivers side firewall where all the wires come into the cab. Thats where I ran mine thru. Theres also a smaller hole right above the brake pedal. depending on the size of the wire it might work aswell. Heres a pic of the smaller hole.
Old Jan 19, 2010 | 05:31 PM
DevinIsPro's Avatar
Thanks I will check it later!
mech cb
Feb 24, 2014 09:59 PM
skarphace
Sep 9, 2012 07:31 PM
oceaneyes823
Jun 30, 2008 04:19 PM
bubba181x1
Mar 12, 2008 02:05 AM
dusted800
Nov 12, 2006 06:56 PM
