wiring an amp
Old Dec 7, 2006 | 06:22 PM
fastpitch321's Avatar
fastpitch321 is an unknown quantity at this point
Default wiring an amp
i just bought my blazer and am transferring my amp and subs from my vw to my blazer. Where in the firewall do you go throgh it? Also, where did yall put the wiring on the interior? thanks.
Old Dec 7, 2006 | 06:38 PM
XBlazer01's Avatar
XBlazer01 has a spectacular aura aboutXBlazer01 has a spectacular aura about
Default RE: wiring an amp
cut a hole in the grommit and run ur power line through there.
I ran my lines under the door sills they pop off. run it in there and then under the carpet to the rear of the truck.
if its 0 gauge ya gotta drill a hole though
Old Dec 7, 2006 | 07:28 PM
cherryred4x4's Avatar
cherryred4x4 is an unknown quantity at this point
I found it easier to drill on the driver side than the passenger side. X, on the newer Blazers you have that option, all the connectors go through my firewall in a big plastic connector.
Old Dec 7, 2006 | 07:31 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
I went through the rubber grommet that my radio antenna comes through... under the carpet on the passenger side...
Old Dec 7, 2006 | 07:39 PM
hillbillyinOhio's Avatar
i did that too on my 97 with 0 ga. on my 92, i had to drill. SInce yours is a 96, pull the passenger side carpet back and you will see the rubber grommet that your antenna wire comes through. Just make sure that you zip tie your power wire away from the engine. had a customer in yesterday that had melted his power wire to the block. sucks for him, at he payed 4 bucks a foot for his 0 ga.
Old Dec 7, 2006 | 08:05 PM
blazinloud's Avatar
omg!!! $4 per foot, thats pure madness!!!
Old Dec 7, 2006 | 08:30 PM
sorry, 4.25 per foot.
clicky
I just buy spools of it.Mine
Old Dec 7, 2006 | 08:38 PM
XBlazer01's Avatar
ROE Store 0 gauge
yea 3 bucks a foot
Old Dec 7, 2006 | 09:06 PM
blazinloud's Avatar
I think the E.D is 2.75
Old Dec 8, 2006 | 10:11 AM
mikeywaynebygod's Avatar
mikeywaynebygod is an unknown quantity at this point
yeah...anything from 2 gauge down is really fun to hide. i've got my wiring going along side my door, under my door sill, under my carpet, and comes out under my backseats. it's really fun getting the door sills to pop back down in place when you've got a wire as big as 3 fingers sticking up.
