Wiring diagram
Old Jan 4, 2007 | 05:36 PM
j1cs's Avatar
j1cs is an unknown quantity at this point
Default Wiring diagram
Someone needed my kenwood 6022 radio more than me. Does anyone know what the wiring diagram is for a 96 gmc jimmy so i can hook up another radio. I can get the color of the wires if need. Thanks
Old Jan 4, 2007 | 06:22 PM
hillbillyinOhio's Avatar
Default RE: Wiring diagram
search function works wonders here on BF.
12v constant is Orange -
12v switched is yellow(larger wire) -
ground is black,
ignore the grey and brown, for must and illumination. don't worry about them
Speakers are
Left Front
Tan is positive - connect to solid gray
Grey is negative - connect to gray with black tracer
Rt Front
Lt Green is Positive - connect to solid white
Dk Green is Negative - connect to white with black tracer
Left Rear
Brown is positive - connect to solid green
Yellow(smaller wire) is Negative - connect to green with black tracer
Rt Rear
Positive is Dk. Blue - connect to solid purple wire
Negative is Lt. Blue - connect to purple with black tracer
thats it. please use some kind of crimpers (crimp caps, butt connectors) on the wiring connections. tape is not sufficient
Old Jan 12, 2007 | 10:18 AM
j1cs's Avatar
I was able to go to used parts yard and get a factory wire for my 96 gmc jimmy and was able to reconnect to my wire harness so it would be back to factory end connections. When they stole my old hu I had to redo the wires. According to the colors of the wires I connected they seem to be different colors or am I not correct? This is what I thought the colors of the wires were> Am I wrong?
Tan
Dark Green
Brown Light Brown
Light Blue
Dark Blue
Brown
Yellow
Orange
Yellow
Light Brown
Brown
Black White Tracer
Old Jan 12, 2007 | 10:33 AM
not sure about the black with white tracer. but everything else looks pretty good. is that your question??
Old Jan 12, 2007 | 10:44 AM
j1cs's Avatar
It seems the colors I have for front speakers are
tan
dark green
brown
light brown
and you were saying
tan
grey
light green
dark green
Old Jan 12, 2007 | 10:57 AM
j1cs's Avatar
Sorry, I must be color blind. I went and looked again and I"m wrong. Everything is correct. Thanks for help hillbillyinohio.
Old Jan 12, 2007 | 10:58 AM
have only ever seen tan, grey, light green and dark green. best way to check, is pull grommet away from inside of door jamb.or pull door panel off. You can test the wires, get a 9v battery and touch one lead to the positive terminal and the other lead to the negative terminal. speaker should pop if you have the right wiring.
Old Jan 18, 2007 | 07:34 AM
dbrown03's Avatar
dbrown03 is an unknown quantity at this point
Just had to mention how helpful this site was to me! Search function DID work wonders and saved my *** after I fubar'ed my little stereo project. What I thought was going to be easy turned out not to be but the suggestions and info I found here pulled my fat out of the fire. Thanks again!
Old Jan 18, 2007 | 09:12 AM
Glad we could help!
phxjosh
Oct 30, 2013 10:03 AM
raptorman
19
Jan 14, 2010 10:21 PM
camaroz
15
Aug 26, 2008 07:44 PM
1989Blazer269
Oct 26, 2006 12:15 AM
chris
Dec 6, 2004 12:47 AM
