04 4dr 4wd build/rebuild
Old Nov 7, 2016 | 04:49 PM
  #131
420Blazin4X4's Avatar
420Blazin4X4 is on a distinguished road
Originally Posted by TMM217
The RC lift wont affect the brush guard mounting. Now if you were to install a PA body lift then I think there's an issue.
yeah I cranked torsion bars?shackles and did a 2 inch body lift..Now I need to figure out how to go about making some brackets to remount it..Either that or I will be posting it online to see if anyone is willing to do an even trade for a black bull bar..
Old Nov 18, 2016 | 07:22 PM
  #132
So getting ready to get 'ol Red back, I've started making new plans already
I've since sold the old roof rack and 40" LED light bar, so I plan on ordering a new rack and stepping up to a roughly 42"-46 " curved bar mounted just above the windsheild. I also plan on mounting a couple LED pods facing the sides and rear for a full 360 degree light output. The end wiring for the roof will have a 4 gauge power and ground running through the roof an a 9 conductor wire acting as signal wires. I plan to mount a small weatherproof lockable toolbox in the rack and run all the wires to it, and I'll house a fuse distribution block and a bank of relays to run all the lighting, as well as a small air compressor and a small tank for some onboard air. Maybe some air horns in the future, just for kicks Going to finally install my CB as well and mount a PA speaker for it up on the rack as well.
I have a winch plate at work that I need to bring home to start mocking up the mounting. Looks like it'll work out well using the factory frame rails, bolting in a couple of 2" receivers like I see people doing that slide a shackle mount into. I plan on running some 2" box steel into the receivers and bolting it all down, then welding the winch plate to the box steel. I'll most likely end up ditching the factory mounting for the brush guard and welding it to the winch plate, if I decide to keep it. The winch plate might turn into a bumper, in which case the brush guard just wont be going back on lol.
I brought this home today to get started on. Sad looking Smittybilt XRC8 that needs some TLC. Going to tare it apart this weekend, regrease, and check out it's functioning. Got it for ZILCH If it works, I'll put a little money into a new clutch lever and a new fairlead, throw a layer of fresh paint on it and rock it!
Attached Thumbnails 04 4dr 4wd build/rebuild-20161118_145420.jpg
Old Nov 19, 2016 | 04:01 PM
  #133
rexmburns's Avatar
Super Moderator
That winch doesn't appear to have even ever been unspooled judging by the cable!
Old Nov 19, 2016 | 07:03 PM
  #134
Yeah it seems pretty mint, it's just had the Florida sun beating on it for who knows how many years so it looks like hell lol. It wasn't even hooked up to power in the Jeep I pulled it off of! I gave it power today to test it and it works GREAT! Going to rip the planetaries apart and regrease it as I hear these XRC's come with grease that's like glue and they're difficult to free spool... I need to pop the side cover off anyhow, the clutch lever refuses to move...
Old Nov 27, 2016 | 05:30 PM
  #135
First addition since getting it back. Had these sitting in the garage for a while, I think I pulled them off a Nissan Xterra. Took a little cutting and bending of the mounts to make fit, but they turned out pretty good Decided I'd mod some from another vehicle to fit since these are pretty much impossible to find for a Blazer...
After a little paint they came out alright. Not prefect, but eh, can't tell unless you get right up on them lol
Attached Thumbnails 04 4dr 4wd build/rebuild-20161127_1318551.jpg   04 4dr 4wd build/rebuild-20161127_131916.jpg   04 4dr 4wd build/rebuild-20161127_164734.jpg   04 4dr 4wd build/rebuild-20161127_164728.jpg
Old Nov 27, 2016 | 07:59 PM
  #136
TMM217's Avatar
TMM217 is on a distinguished road
Wow those fit great.
Old Dec 7, 2016 | 05:05 PM
  #137
Brought home some goodies from work today
Winch plate; actually slides right in between the uprights on the brush guard, so I should be able to keep the brush guard and maybe even beef it up a little by attaching it to the winch plate! Also a pair of 30x9.5 Cooper MT's that I had originally got for spares, but I may just wait and see if another good pair come in, or if I get antsy maybe just buy two new ones, these two are in MINT shape! Came off the rear of a little Suzuki, the owner must have lifted it and never done an alignment because these rears look great while the fronts were SHOT lol
Also a spare intake setup complete with MPFI spider, just 'cause actually my lower intake is cracked! That's what prompted me to seek out a replacement... I've had it sitting around at work for a while, only just decided to bring it home... Last time I changed my thermostat, the forward most bolt that holds the thermostat housing down grabbed the threads in the lower intake and busted a chuck off, and a bolt will no longer thread threw... My fix, a C clamp... But hey, it 'aint stupid if it works! It's been holding like a champ since and it's been almost a year, and unless I have a more serious reason to pull the lower intake off, it's staying that way lol. So for now I just have the spare parts in the garage, needing a cleanup, but they'll be ready when I need them!
Attached Thumbnails 04 4dr 4wd build/rebuild-20161207_175324.jpg   04 4dr 4wd build/rebuild-20161207_175340.jpg
Old Dec 8, 2016 | 07:31 AM
  #138
Tajohns34's Avatar
Nice grab on the tires. Working at a salvage yard definitely has its advantages.
Old Dec 9, 2016 | 10:47 PM
  #139
95teal4x4's Avatar
95teal4x4 is on a distinguished road
These came out looking bad*ss. There is a nissan xterra sitting in the u pull it junkyard i go to that i think has tail light covers like this. I never thought of using them. I might have to go pull em lol
Old Dec 10, 2016 | 11:46 AM
  #140
they take a little massaging but they fit pretty well if you're willing to work with them
