1983 s10
Old Feb 18, 2011 | 05:01 PM
52 jimmy's Avatar
52 jimmy is on a distinguished road
Question 1983 s10
What larger v6 would be an easy swap in to my 83 s10 5spd chassis??
Old Feb 19, 2011 | 08:19 PM
neo71665's Avatar
What engine did it have?
Old Feb 20, 2011 | 08:52 AM
old skool luvr's Avatar
well.....if it's a '83 neo, it'll have the 2.8 in it.
your best (& easiest) bet is to find yourself a complete donor truck from the '93 & down S10 p/u's or '94 & down Blazer/Jimmy's. the Bravada's only came in AWD.
this way you can do a complete driveline & wiring harness swap, and there will be no custom work required.
all of the exhaust, drive shaft, cross member (which is different for the 700R4 compared to the 200 that is in your truck now), engine mounts, etc will bolt right up to your truck. even the newer ('86 to '94) dashes bolt in. swap over the steering column for a tilt unit as well.
in fact, if you are good @ making mods work, try finding a newer ('98+) truck and swap away. same chassis in the truck as well, but the electronics will take a little bit of work to fit to your cab (different location for the computer & wiring harness through the firewall).
not a really hard project to do if you're gonna stay in the 1st gen platform.
GL & keep us updated with a build thread when you start it.
Hauntdhouz
Engine & Internal
Dec 14, 2012 08:01 AM
mxpxpunkrock1987
Jun 15, 2011 06:02 AM
mxpxpunkrock1987
18
Mar 23, 2011 07:34 PM
mxpxpunkrock1987
Mar 9, 2011 10:43 PM
syxpack
Oct 27, 2008 09:08 PM
