1986 s10 blazer project
Old Aug 6, 2009 | 08:36 PM
  #91
bobditts's Avatar
bobditts is an unknown quantity at this point
here is what im thinking for the gauge cluster. simple and basic. I already have all the gauges (autometer). The only thing I might change is instead of flat all across the top, making it a slight arc.
Old Aug 9, 2009 | 09:06 PM
  #92
Baja Blazer 85's Avatar
Baja Blazer 85 is on a distinguished road
I'd go with a slight arc, that would give it a bit of spice.
No rev counter? I know its an automatic, but I like having one in mine (mechanically identical to yours from factory)
Old Aug 9, 2009 | 10:23 PM
  #93
bobditts's Avatar
nope, no tach. It is an auto like you said and I dont plan on doing any engine performance mods to it so I dont see the need.
Old Aug 10, 2009 | 09:46 PM
  #94
bobditts's Avatar
Installed the torsion bars today, connected the y-pipe to the exhaust manifolds, and finished some wiring. Filled the t-case with fluid. About ready to crank it over. A few more small items and it will be good to go. Only took me 5 months!
Old Aug 12, 2009 | 06:06 PM
  #95
bobditts's Avatar
OLE BLUE LIVES!!!!! A few small things I still have to do before I take it for a test drive. I quickly cycled through all of the gears and they all sounded perfect. The belts are a little squeeky though. Does that mean they are too tight, or too loose?
Old Aug 13, 2009 | 12:04 AM
  #96
Blazin_Jason's Avatar
I would say in need or replacing or too loose. Don't forget your alignment before you drive it too much.
Old Aug 13, 2009 | 06:34 AM
  #97
bobditts's Avatar
I also heard too loose from other people as well. I will try tightening them up. They are in great shape so im pretty sure they dont need to be replaced.
Old Aug 14, 2009 | 06:36 PM
  #98
bobditts's Avatar
Just drove Ole Blue around the block a couple times. Seems to be running excellent. Im about to go get it above 25 Miles and hour. Hope nothing catastrophic happens.
Old Aug 15, 2009 | 02:54 PM
  #99
bobditts's Avatar
I headed out early this morning with a buddy (05 jeep liberty w/ tow package thank god) for an hours drive out east to some farmland to go target shooting. Make it 90% of the way then the engine died. Realized the fuel pump wasnt working. I was determined to go shooting so we hooked up the tow strap and he pulled me the rest of the way. Once we got there I decided to go over the basics and found a popped fuse. Ended up replacing it and it works great again. THANK GOD!!!! If anything major breaks on this thing im parting this b!tch out!
Old Aug 15, 2009 | 11:24 PM
  #100
PaulW's Avatar
PaulW is on a distinguished road
why did you put the 2.8 back in? i can understand wanting a pretty engine bay and all, but it seems like polishing a turd. was the small block swap out of the question?
