1995 s10 blazer 4x4, 1978 350 700r4 2wd swap help please
Old Sep 18, 2018 | 08:46 PM
Benjamin Trianni's Avatar
Benjamin Trianni is on a distinguished road
Default 1995 s10 blazer 4x4, 1978 350 700r4 2wd swap help please
Hi I am new to the site and can't seem to find the answers I've been trying to research. The threads I've been reading are pretty old I have a 1995 s10 blazer 4.3 with 4l60e I'm looking for information and parts needed to put in a carburated 350 and a 2wd 700r4 trans that is brand new. please correct me if I'm wrong, that's why I'm asking is because I need help. the (easiest in my head) way to do this would be to pull engine and trans mission from the blazer, remove front axles. buy the swap kit from jegs would I need 2wd kit then or still 4wd? and put in the 350 and 700r4 buy a 2wd blazer driveshaft to use with 2wd 700r4 (yes I know I would loose all original gauges) use a different radiator with ford Taurus fans buy fuel pressure regulator with return line to keep pump cool for the carb or use mechanical pump on return line from tank is that about it? Or what am I missing please help - thanks BEN
Old Sep 18, 2018 | 09:16 PM
If your converting from 4wheel drive to 2wheel drive, you will need to converted the front end spindles... maybe the suspension... not too sure honestly, but I know you cant leave the 4wheel spindles without the cv axles.
justkeepchuggin
May 18, 2013 09:54 AM
chris015
Sep 17, 2011 07:31 PM
toplessvw
Aug 5, 2009 01:13 PM
matthewbarr1
Jun 12, 2009 05:41 PM
DUI Motorsports
Oct 23, 2008 05:55 PM
