2000 ZR2 2wd conversion
Old Aug 4, 2020 | 04:37 PM
2wd spindles have a part coming out for the different front rotors with bearings to sit on. Lots more work then what I would do, but doable...
drop it down and that would be a sweet street racer that would hug the pavement I think lol... I'm starting to like the idea of this build more and more... just a shame itll be the death of another zr2 lol... the stance of an LS would be skinnier then the zr2...
Old Aug 4, 2020 | 05:50 PM
Oh, I just thought of this. Running the front end with only the hubs with the CV axles deleted is bad.
I'm sure you already knew this but I thought it might be useful to others.
I was going to mention this too.
Easiest option is you can just rip your axle shafts apart and keep the out stub axle portion, insert it into the hub as it would normally be installed, and leave it in when the center nut torqued down. That'll save you're bearings from coming apart.
Old Aug 9, 2020 | 06:04 PM
Xracing1's Avatar
Xracing1 is on a distinguished road
yep that’s my plan.
Old Aug 9, 2020 | 07:02 PM
Xracing1's Avatar
so I have a theory DonL can I use the 2wd drop spindles and hubs on my blazer? And does anyone make tubular a arm?
Old Aug 9, 2020 | 07:31 PM
They might work, might have to double check mounting location difference between the 2wd and 4x4.
For the tubular a arms, rough country does, but they have a different angle for a lift not drop.
Old Aug 9, 2020 | 10:39 PM
Xracing1's Avatar
I have a question a Syclone and typhoon was 4wd or awd I guess how did the factory get them so low?
Old Aug 10, 2020 | 03:24 AM
Theres drop kits for the 4x4s... a lot of people have gone that route instead of jacking them up on here...
Old Sep 5, 2020 | 04:19 PM
Xracing1's Avatar
Well gotten a little bit done. It’s been over a 100 here for weeks and as you can see I work outside. But I got the engine and trans pulled out and the front diff. Removed I did disassemble the CV axles and reinstall them in the hubs. I installed the new cam and matching valve springs and seals the headers came in so I think I’m ready to install the engine tho I might wait until I install the shift kit in the TH400 and stall them both and the same time. Not much to show yet but here’s a couple pics of the engine and my new race star wheels.
Old Sep 5, 2020 | 04:58 PM
Looking good... I like the rims... ehat with the tube on the water pump?
did you look into the spindles some more?
Old Sep 5, 2020 | 08:06 PM
Xracing1's Avatar
is a steam vent that is normally in the radiator.
Yes I think there going to work but I want to go to the pick a part and get a factory one and try before shelling out the money for drop spindles.
