2001 LS off road build
Hey guys I'm new here I have a 2001 Chevy Blazer it is my daily driver but I'm building it for off-road use also I already have a rough country two and a half inch width and was wondering if anybody had any ideas on doing the coil over conversion with this lift.
Quilt over?? Coil over, not sure if it can he done, anyway I have a 4 door ls, not the best for off roading unless you change a few things, i needed to get a custome front shaft as the zr2 blazers have a longer one, the rough country shocks are garbage ×10, I have gone through 4 pairs in 3 years. As i am now changing to bilstine 1500 if i can find some that fit!, the steering box is (sloppy) i added a rough country steering stabilizer, the leaf springs are very long and can be worn down very easily if you load up. I'd recommend adding 2 more stacks. Also fitting 32inch tire you will definitely need ofset rims and to cut a bit of rear bumper.. do your fuel pump befor any of this stuff.
The truck is very capable off road if you know what to do |
If you dont do your driveshaft you can stretch it right out, and I damaged my tranfercase
Some quick thoughts:
(Post 735465)
I also added a trans cooler, double rad in the front 1 for engine 1 for the trans 1 ton idler arm send a part number over if it fits with no issues what about pitman arm? |
Originally Posted by BritishColumbiafishing
(Post 735506)
Temp gauge is a great idea for the trans. Mine was getting getting hot at one point ( story for another day)
I also added a trans cooler, double rad in the front 1 for engine 1 for the trans 1 ton idler arm send a part number over if it fits with no issues what about pitman arm? As for the 1-ton idler arm upgrade, the parts of off the shelf except for the brack I got from here: https://www.outfitterdesign.com/1-to...m-bracket.html I'm not a crazy off-roader but I like the idea of having peace of mind when it comes to my suspension! :) |
(Post 735517)
I basically lost my 3/4 clutch pack because I towed with my transmission in overdrive. D'Oh. I should have known better!
(Post 735801)
So my idler arm is toast again. Before I order this at my parts store , can you confirm it fits, because online it says does not fit 2002 blazer ls 4 door? Just double checking with you
I plan to get under the truck for some preventative maintenance and check on my idler arm in the coming week. I can take a look at the fitment then if you can wait. Where did you see that the bracket would not fit a 2002 LS 4dr? I didn't see that at the link at outfitterdesign.com. |
(Post 735805)
I have not installed the adapter bracket yet.
(Post 735807)
When you search the part number
