'77 lift kit
Old May 3, 2009 | 11:46 PM
ilovechevys's Avatar
ilovechevys is on a distinguished road
Default '77 lift kit
Hey all. I have a '77 blazer for my first car and my dad and I put a 4" lift on it. My dad says it rides a little stiff in the front and is considering going with some soft ride leaf springs but i don't think it is that intolerable. Any way, i was wondering if there is any easy fix for it without buying a whole new set of springs. If anyone has any input it would be much appreciated. Thank you.
Old May 4, 2009 | 01:41 AM
bandidolenny's Avatar
I have owned and lifted many 73 through 91 full size Blazers and Suburbans. I will guess right now that you guys probably replaced the front leaf packs and installed blocks in the rear didn't you? This results in a new "stiff" front suspension and a 30 something year old "soft" rear suspension that just sits higher. If you guys want to spend anymore money, I would recommend new rear leaf packs to compliment the new front ones. By the way, you did install new shocks right?
Old May 5, 2009 | 12:32 AM
we actually got the lifts off of a donor truck, im guessing it's a 76 1/2 ton chevy and the rear is on blocks. And yes, we suited it with all new ranchos so there is no problem there. and as far as the new packs on the back, im not any rush because i personally like that raked up front end.
B.T.W. what size tires can i run on it? We are planning on staying with the original ratios on the diff's
bigdaddykane93
Feb 24, 2013 02:30 PM
Jkrumm
Lifting Tech
Feb 17, 2011 04:35 PM
jjsmith1228
Oct 31, 2010 03:56 PM
ericthughes
Lifting Tech
Oct 13, 2010 10:56 PM
Blazer man
May 11, 2005 04:29 PM
