'93 blazer meets old school
So, I picked up a 1993 Blazer a few months back knowing the mechanics of it will need work. The original plan was to do a basic rebuild on the engine and transmission....but it morphed into a custom off the chassis rebuild/custom mod.
As it stands, I have 90% of the interior taken out. Hopefully in the next few weeks I will get the rest done and lift the body off. The frame will be blasted and coated with POR-15, then put the body back on. This is where the fun starts. Original parts being trashed: fuel injection a/c unit wiring harness dashboard transmission anything electronic Replaced with: carburetor & mechanical fuel pump maradyne heater/defroster rewire everything to an under the hood fuse/relay box from a 98 jeep Cherokee fabricated metal dash 700R4 transmission That is a very short and broad stroke of the game plan. As far as the wiring, i am shooting for it to resemble the simplicity of something from the 1950's. No, it is not "emp proofing my car"....simply put, I am tired of dealing with electrical/electronic issues in new vehicles. I am trying to go as mechanical/non-electric as possible. Well, more to follow soon!! |
Sounds like fun to me. While I appreciate the sophistication and efficiency of computer controlled systems, I like the concept of my daily driver being simple enough to repair with a bag of tools you keep under the seat. I'm slowly working back to that goal. LOL
What kind of carb are you planning to run? |
sounds good I had a 95 with a 4.3 that I bought and it had a 4 barrel carb on it some of the wiring, like for the sensor were just cut and connected. basic you just need a standalone harness power to dist cap , alt to fuse box, and some other somethings.
my 4.3 had a quadrajet carb with I liked a lot cause if im right its a 2 barrel and when vacuum drops under load it opens secondary for a 4 barrel |
now don't know if this is true but I had a 700r4 in that same car and never had the neutral or reverse switch hooked up never looked into it but It can stop somethings from working like the reverse lights for inspection and also my rear hatch would never open because it never knew it was in park so I had to pushe brake down to open it
Originally Posted by xillzxnickx
(Post 597243)
my 4.3 had a quadrajet carb with I liked a lot cause if im right its a 2 barrel and when vacuum drops under load it opens secondary for a 4 barrel You can also get them in 950cfm models. LOL |
950cfm is a extra 100 hp. LOL. and fouled plugs.
Keep in mind,alot of manifold swaps on these balanced shaft engines have clearance issues with the balance shaft. People had grinded em down,or they have removed them completely and replaced the holes with freeze plugs. |
I think hes planning to go to a 350, but even still I agree, 950cfm is waaaay overkill for most small block engines IMO. If you had a long enough cam duration to really use one you'd have NO vaccum to run anything and have to switch to a hydro brake boost.
2 Attachment(s)
Originally Posted by Crackers
(Post 597242)
For what I have on hand to work with, what time I have available to mess with it, and what funds will allow in stages...once the frame is repainted and the body is back on, I will be working on it from the rear forward. The decision behind this is the wiring I will be doing. With the wires that are in the rear of the vehicle, not to mention from the roof, i rather run the furthest wires to where the fuse box will be. Now, as far as the roof, for the flood/spot lights, this was my thought on connecting them: https://blazerforum.com/forum/attach...ine=1376766346 With the 4 pin connector, I have 2 pins for positive and 2 for ground for 2 sets of lights. This will remove the need for having the wires go through the door jam, I can disconnect them without disturbing the wiring if i need to, and it will be a weatherproof seal between the roof and inside the cab. Well, got the factory heater/AC unit out today and a fair amount of the trim. Few more things to go and the interior will be fully empty. Has anyone had issues trying to get the interior bolts out because of the gray putty-like substance??? That stuff is a pain in the butt!!!!! Well, there is still daylight I could be using to keep working, so back to gutting the inside I go!! |
I like the idea of going back to simple with a carb, but where do you live that it's legal to do that? Or will this just be an off road toy, so you don't have to worry about vehicle inspection? Around here anything less than 25 years old has to pass emissions.
I would love to ditch all the electronics on my '95, but I wouldn't be able to get the thing inspected. |
1 Attachment(s)
Where I live, the carb will not be an issue for inspection.
The mailman brought this to me today: https://blazerforum.com/forum/attach...ine=1376772175 Just like the connector for the roof lights, this is a drill through cb antenna mount. Drilling through the roof, install the weatherproof antenna base, and run the wires through the body. The antenna and spring can be kept in the cargo area and the black cap is screwed onto the base when the cb is not in use. I am going to have to get the cargo basket sometime soon so I can mount that and figure out where i need to drill the holes out on the roof. |
Try heat and a scraper/ wire brush.
Originally Posted by cleburne red
(Post 597302)
Originally Posted by Rjay
(Post 597367)
2 Attachment(s)
Well, the interior is about done. Waiting on a second set of hands to come over and help remove the brakes, steering column, and headboard. That should do it for the inside.
I will start taking out the gas tank, transmission, and transfer case tomorrow. If I have time after that, I will gut out what I can in the engine compartment. |
How long dis it take you to pull the dash and climate controls? Are you gonna put the AC back in?
4 Attachment(s)
With the help of a friend, a few large cans of red bull, and motivational music blasting....for the entire dash and heating/ac unit removal took about 2.5 hours.
I will not be using the factory heater or AC. I will be using the AC compressor for a on-board air compressor conversion, and for heat I will be using a Maradyne Stoker Heater. The unit is only 7.5" H x 11.5" L x 8.7" D, compared to the original one (see attached photo). The original dash is now junk and I will be doing something like this: https://blazerforum.com/forum/attach...4&d=1377441666 |
After I get off a few more rusted on nuts and bolts, and get a few components out, I should be good to go on taking the body off. If anyone has done this, would you know if a few saw horse style brackets with 6X6 cross beams be ok to hold the body up? Keep in mind that the front fenders will be off, along with the hood and doors?
Once the frame has been blasted and coated with POR-15, the rebuild should go much faster. |
