I say dont spend money on wheels because youre going SFA unless you plan on dana 30/8.8 and wheel adaptors, but if you dont plan on those axles, i say dont waste the money.
(Post 641021)
Like Kyle said the astro box will be the better way to go with soa. I have an astro box with a flat pitman and my drag link and tie rod are almost parallel. I have no bump steer at all with my setup.
https://blazerforum.com/forum/attach...ine=1420230575 i used to run 33 12.50 all terrains on a stock s10 set up and the cv joints just wont hold up. everytime i had to turn the wheel more then like 180 degrees they would grenade. now my s10 has 10bolt chevy axles, welded rear axle and 33 14.00 boggers and still using the same axles with no breakage. just normal wear and tear if you want to daily drive and occasionally offroad that thing maybe a body lift and some skinny 31s |
Sorry I haven't posted in awhile. Work has been crazy and I'm only home on the weekends. But I did get my d44s from a 97 rodeo and a 87 grand waggy. My uncle has the axles right now and he is gonna paint, and rebuild them for me. I got the parts order for the axles too.
I'm goin with Motive Gear Axle shafts Yukon Gear 4.30 ring and pinion Detroit Lockers |
I know I haven't been on for awhile but I've been dealing with stuff with some family stuff. But good news is that the axles are done and painted. But I'm not gonna do the swap just yet cause I don't have another vehicle to drive while the blazer will be down. I haven't done much to the blazer other then put led lights in my domes and map lights.
To do list for this summer Finish LEDs inside Fix my 4wd Redo my stereo system Fix my radio antenna Put a new grille in |
Sorry that I haven't updated for awhile. Im not doing SFA anymore cause my sister is going to be using my blazer and she won't be able to get in it. I'm keeping the axles tho for a future project. I'm going to build a slightly lifted daily on 31s the I can take through the easy trails at my buddy's farm and the offroad park near me.
I figured I'd make a new to do list. To do Led interior lights Pumpkin 6.2 double din hu Alpine type r 10" sub (not sure on amp) New grille, bumper, valance fenders and hood Fix rust Zr2 axle and iron diff with 3.73 gears Manual 4wd (almost done) New wheels (not sure what kind) Tint Exhaust Change shackles Body lift Led light bar Already done Crank tbars and shackles Tb mod Quad beam mod |
5 Attachment(s)
Some pics
Did some flexin on an old ramp at my parents house.https://blazerforum.com/forum/attach...ine=1433226236https://blazerforum.com/forum/attach...ine=1433226236 Some inside pics. Yes I know I need to clean it! It sucks working for a logging company I can never keep the floorboards clean.https://blazerforum.com/forum/attach...ine=1433226236https://blazerforum.com/forum/attach...ine=1433226236 I got off work last night and when I was backing up I didn't see a stump and bam. https://blazerforum.com/forum/attach...ine=1433226236 |
Finally an update. I got me zr5 wheels from my boss today. I'm gonna sand them done and repaint them. The paint is flaked off bad around the edges. Ill post pics soon.
3 Attachment(s)
If you're still wanting to make bumpers you can check out my build thread for a very simple front bumper design. It's held up very well for me so far. https://blazerforum.com/forum/builds...r-build-80458/
Thanks Zach. I'm not sure if I wanna build bumpers now or not. My build took a different direction. I'll keep it in mind though.
I picked me some bravada hvca knobs and grand Prix gauge needles today at work hopefully I get them on this weekend. |
