Axle swap
Old Jun 8, 2022 | 07:39 PM
Big_P's Avatar
Big_P is on a distinguished road
Default Axle swap
So I've got a 95 jimmy blazer 4x2. I was wondering all what I would have to do to stick a 95 chevy 3/4 ton rear axle in it. If I have to I will settle for 1500 axle. I just wanna be able to pull trailers. Current setup she be squatting. Gunna add bags eventually and Currently rebuilding motor. ALSO: Any tricks to getting top 2 bolts out to separate engine from tranny? Thanks.
Old Jun 8, 2022 | 08:55 PM
Hess13x's Avatar
Either of those axles will be 6+ inches wider than your current axle. I would recommend an add a leaf to the rear spring pack. As far as the top 2 bell housing bolts a swivel head ratcheting end wrench helps also put a jack under the trans and unbolt the crossmember and let the tans down a few inches. This will give you more room to get to them.
95blazin
May 7, 2011 09:13 PM
92blazin
Dec 22, 2010 05:46 PM
robbiegamble
Feb 14, 2009 12:20 PM
jpkoest88
Apr 3, 2008 02:28 PM
walkingtall
Oct 30, 2006 01:12 PM
