BDS 5" Envoy lift
Old Apr 2, 2013 | 03:40 PM
  #101
okiedoak20's Avatar
im at 12degerees both pinion and drive shaft, i may play with it some more and look into a double cardon (double universal) drivshaft on the transfer case end,that should eliminate all the vibration completly..
now i just need to find some one to install a set of rear gears for a resonable price
Old Apr 2, 2013 | 05:05 PM
  #102
Diaita's Avatar
A CV will fix it up for sure, that's my next project with a SYE to get rid if my vibration. My driveshaft is at around 20 degrees, and the vibration won't go away no mater what angle I try running the pinion at.
Old Apr 6, 2013 | 03:45 PM
  #103
okiedoak20's Avatar
i started playing with the stock parking brake cables, and purchaced a new p-brake equalizer, come to find i was able to make the stock cables reach and was able to adjust the cables to have parking brakes once again, yea!!
Old Apr 6, 2013 | 03:46 PM
  #104
okiedoak20's Avatar
also attached the rear brake line extension, worked just like the instruction said, whattya know..
Old Apr 17, 2013 | 02:22 PM
  #105
timsawyer2002's Avatar
timsawyer2002 is an unknown quantity at this point
i have a 04 blazer that i need some help and answers to if u can help please let me know
Old Apr 18, 2013 | 03:52 AM
  #106
okiedoak20's Avatar
Timsayer, ok ask away
Old Apr 18, 2013 | 04:37 PM
  #107
i have a 2004 chevy blazer when i try put it in four high the light flashes and goes back to two hi or does nothing at all. i can put it in four low and i can hear the t.c. lock in and the switch inside goes to four low. well went to pull my wife's truck out last weekend and i put it in four low and all it would do is grid cause it wouldn't go in four hi. so i thought i would try and pull her backward's ( by me going in reverse in my truck) the front end worked untill i hit bout 3000 rpm and it like jumped out of four wheel drive just a second when i let of the gas and pressed it again the four wheel drive worked. as long as ur going backwards the four wheel drive works but will do nuthing but grid trying to go frontwards. any ideal what might be my prob. i have checked the vac lines under the battery and the actarator to they both seem to be doing there job. any help would be greatful. thanks
Old Apr 18, 2013 | 05:20 PM
  #108
Diaita's Avatar
Old Apr 18, 2013 | 06:23 PM
  #109
so what do you think the problem my be?
Old Apr 18, 2013 | 06:25 PM
  #110
when it say run a jump wire to do the trouble shooting it's it the same way as you would do it on a 12 pin? are the ground wire and the j wire in the same spot
