Good gawd that's a serious crimper. As someone who has tried to crimp wire like that with vice grips (unsuccessfully) I am very impressed with those crimps.
I really like your fender flares.. what brand?
Those would be zr2 flares.
where did you get those battery terminals at?
Originally Posted by Thogert
(Post 578792)
Originally Posted by 210cnj
(Post 578817)
(Post 578834)
Originally Posted by bryanbc
(Post 578947)
Store Awes guy builds them. He's building my busbars for my for when I get my fifth D3100 :) |
8 Attachment(s)
More updates.
Got 8 runs of 0ga front to back done. Have a few more things I want to do to become more comfortable with it. It was bitch to run on the exhaust side plus the 4wd. Nothing is easy in this mofo. Getting it stripped down https://blazerforum.com/forum/attach...ine=1367294352 Foam https://blazerforum.com/forum/attach...ine=1367294352 Cutting it open! https://blazerforum.com/forum/attach...ine=1367294352 Yes, they're as long as they look. http://i275.photobucket.com/albums/j...ps6e584c89.jpg Ground runs https://blazerforum.com/forum/attach...ine=1367294352 One of those runs is strait off the alt. https://blazerforum.com/forum/attach...ine=1367294352 https://blazerforum.com/forum/attach...ine=1367294352 Missing the inner fender well on this side well splash part of it... Soooo, KOB zip ties and mustache tape it is. https://blazerforum.com/forum/attach...ine=1367294352 Yes it looks horrible right now. https://blazerforum.com/forum/attach...ine=1367294352 |
7 Attachment(s)
More to do. Needed to up grade the highs bad.
https://blazerforum.com/forum/attach...ine=1367294443 Putting the tweeter in the stock location. https://blazerforum.com/forum/attach...ine=1367294443 This was fun. The tweeter wires are the nice blue ones. https://blazerforum.com/forum/attach...ine=1367294443 The stocks are a little beat up. https://blazerforum.com/forum/attach...ine=1367294443 Much better :) https://blazerforum.com/forum/attach...ine=1367294443 Got that redneck going. https://blazerforum.com/forum/attach...ine=1367294443 And some redneck rappin :) https://blazerforum.com/forum/attach...ine=1367294443 I'm loving how the comps sound so far! Sorry for the delayed responses and updates. But I have a temp sub stage in the works. two of my 18s on about 5k |
Cool build. I'm not going as crazy as that, but maybe (4) 15's. I do have a couple of questions for you:
-Did you have to regulate the alternator? Is the 15+ volts your gauge is reading bad for it? -How does the foam work? Does it make it more solid sounding and not echoey? -Are you going to "line" the rest of the interior with some sort of sound deadener? Have you ever used just rubberized undercoating? Or liquid bed liner? Can't wait to see the finished product...may have to ride over and look at it in person. I'm only about 2 hours away. |
Originally Posted by 94_FoeDoe
(Post 582738)
-Did you have to regulate the alternator? Is the 15+ volts your gauge is reading bad for it? -How does the foam work? Does it make it more solid sounding and not echoey? -Are you going to "line" the rest of the interior with some sort of sound deadener? Have you ever used just rubberized undercoating? Or liquid bed liner? Can't wait to see the finished product...may have to ride over and look at it in person. I'm only about 2 hours away. For the alt, it has an internal regulator. My gauge only reads 14.1-14.2 I will say, I don't suggest charging higher than 14.8 daily. 15.5 is ok if you're doing a quick burp. The foam helps strengthen then panels and take some resonation out of it. Really helps more with strength though. Yes I will be adding a lot deadener. I'm a firm believer in adding the proper amount deadener. Most likely alpha damp and stinger roadkill expert. |
5 Attachment(s)
Got some updates.
Got my sexy busbars in :) https://blazerforum.com/forum/attach...ine=1369682458 Nice and clean https://blazerforum.com/forum/attach...ine=1369682458 FTMFW https://blazerforum.com/forum/attach...ine=1369682458 Driving around the old Six Flags in New Orleans. Pretty crazy. https://blazerforum.com/forum/attach...ine=1369682458 https://blazerforum.com/forum/attach...ine=1369682458 |
