Blazer body swap
Old Jan 2, 2010 | 08:19 PM
hrn006@aol.com's Avatar
hrn006@aol.com is on a distinguished road
Default Blazer body swap
I have completely rebuilt a 1978 Blazer from the frame down and have come to the conclusion I would rather have a truck. Having over 5k from the frame down, I would like to swap the body out for a C-10 (65-72) body style. Has anyone ever done this? I believe the wheelbase for the Blazer is 106.5" and the C-10 is 106.5". Is there an easy way to do this?
Scot
Old Jan 3, 2010 | 07:35 AM
The K5 is a shorter wheel base at 106.5 as you have stated. I believe that the shortest pickup (the short bed) came in at 115 while the long bed was 127.
You could just build a removable wall for behind the cab on your truck to make it a short pickup.
Old Jan 3, 2010 | 08:57 AM
I really want the older body style.
Old Jan 3, 2010 | 06:30 PM
oktain's Avatar
Get a body, and just chop the box of the C-10 body to fit the wheelbase... it can be done... with $$$$
Old Jan 3, 2010 | 10:38 PM
JRob238's Avatar
JRob238 is on a distinguished road
Wouldnt really take that much money as long as you have the tools.
cut somewhere around where the red line is and take out enough to make it 106.5 or whatever you need then weld it back together. Should be pretty simple.
Old Jan 4, 2010 | 01:56 PM
86Blazer327's Avatar
86Blazer327 is an unknown quantity at this point
I dont think youll ever get it to fit. The frames are way too different on the K5's versus the pickups. The pick up frame is straight all the way till you get to the wheel well , the K5 frame starts to kick up behind the front seats. My opinion is if you want a truck , get a truck. Find a roller and swap all the guts from the K5 to the truck. Yeah you could shorten the bed like others have stated , but I dont think youll get it to fit right
Edit: Go to CK5.com and search. Its been done but I dont think they used the bed. Which is what would be the pain in the butt to fit.
Old Jan 4, 2010 | 09:17 PM
abig84's Avatar
Yeah as was stated. I believe the bed can be mounted but it sits a few inches higher then the cab
Old Jan 5, 2010 | 01:03 AM
JRob238's Avatar
Well if you have the tools and are REALLY REALLY wanting to use that frame there is always the option of cutting the bend out of the frame and welding another straight peice in. BUT you could be damaging the rigidity of the frame. You would really have to take your time and do it right.
But I agree with 86blazer327. You would probably be better off just buying a whole truck.
Old Jan 5, 2010 | 08:14 AM
Pick up a first gen K5 and get the 1/2 cab top for it. Short pickup with the older body style!
Old Jan 6, 2010 | 06:33 PM
Hondo's Avatar
Hondo is on a distinguished road
Scot
Remove the rear fiberglass top (only a few bolts hold it on) and fabricate a panel from sheet metal or fiberglass to box in the rear of the driver/passenger compartment which will make the 78 K5 into a very short pickup truck. I saw one done like this years ago and it was a very good looking truck.
I remove the top from my 77 K5 when the weather permits.
Jamieson
Sep 17, 2013 10:13 AM
Jamieson
May 27, 2013 05:41 PM
MyS10Blzr
Sep 1, 2012 09:44 AM
ktmrider34
Oct 25, 2010 09:38 PM
91 Streeter
Engine & Internal
Feb 1, 2007 10:56 AM
