Bowtie removal and replacement
Dumb ? I know... I want to black out my bowtie, easy enough, but what do I need to use to re-stick it on so it comes off easy again. (just in case)
The front bowtie on the grille is actually bolted on. If you pull the grille off (grab firmly under the center bar and pull towards you) you will see two plastic studs with nuts on them securing the bowtie to the back of the center bar. Use a socket wrench to remove the nuts and the bowtie should come right out.
. I like the idea of just taping it off and painting it when its on the truck, seems a lot easier.
What I did was a little more time consuming, I pulled the bowtie off, peeled the gold plastic off of the plastic insert (which has the two studs that bolt the bowtie on) and painted the insert black, then I just put the insert on. I stripped and re-painted the inside of the gold platic silver and have it ready to stick back on if I ever decide to put the front-end of my truck back to stock.
Took be about an hour to strip the paint off the gold plastic with a rag and laquer thinner.
my badge on the front WAS secured with botls and then of course i removed it to paint the grille and the bowtie seperatly and of course the bastards broke so mine is now stuck on with BLACK3M double sided moulding tape seems to be holding up well so far
