Caliper Mount Bolt Size
The caliper is mounted to the spindle using a combination bolt/slide-pin. The bolt has 7/16-20 threads on it and I believe it is a 3/8" socket head bolt.
The bolts that bolt the wheel bearing/hub assembly to the steering knuckle (with the brake shield sandwiched between the two) should be M12x1.75 thread 50mm long and should have a 15mm hex head on them if I remember correctly.
Johnr2604
Oct 14, 2013 07:54 PM
cleburne red
May 27, 2013 07:47 AM
