Door Alignment question
Old Jan 29, 2014 | 04:35 PM
Kuthe64's Avatar
Kuthe64 is on a distinguished road
Default Door Alignment question
First time posting on the forum so ill try to get everything right.
I have a 2003 4dr 4wd chevy blazer
I replaced both the pins and the bushings on my driver side door and the alignment is perfect, but now the door closes too much. what i mean by this is the door is closing so much that i cannot open the rear driver side door when the driver door is closed. Also it is taking small chunks out of the striker pin.
Is there a way to adjust the striker left and right? I know that you can adjust the depth but when i loosened the screws it didn't look like it would allow me to adjust it so it catches the door sooner.
Also I let the problem of the sagging door go on for longer than i should have. Could i have permanent damaged the hinges and that is why it is closing to much?
anything else i can adjust?
Any help would be greatly appreciated. Thank you
blazen_red_4x4
Oct 13, 2014 12:39 PM
ChevyMan67
Apr 19, 2014 11:24 AM
TRUNK
May 8, 2011 04:25 PM
ClueMeIn1989
May 19, 2009 08:38 PM
MHPrior80
Jan 11, 2008 12:12 AM
