Firewall cmplete
Old Feb 17, 2022 | 05:57 PM
mr.vls's Avatar
Default Firewall cmplete
Today I finished reassembling the firewall on my 89 S15 Jimmy 2Dr, 2WD.. The front clip is removed and engine is out. The next step is to reinstall the engine.
Old Mar 12, 2022 | 06:29 PM
boudreaux55's Avatar
Lookin good..
Old Mar 12, 2022 | 06:30 PM
Double check all grounding straps around distributor area etc
Old Mar 12, 2022 | 07:15 PM
mr.vls's Avatar
Ground straps are installed, Back of right head to the wiring harness, Back of the left head to the firewall, From the battery to the engine, core support and the frame.
Old Mar 29, 2022 | 04:56 AM
Firewall puzzles
Pre paint.. 97 jimmy 4x4 4dr parts
4.3L fresh vortec, all 97 jimmy underneath
54 dodge panel
Old Mar 29, 2022 | 12:40 PM
mr.vls's Avatar
Looks Great, Good Job. Right now I have the engine installed, wire harness is connected to everything, Core support is in, Inner fenders have been blasted, painted and installed. I brought the fenders to the blaster yesterday. The blaster just called and said the fenders have been blasted. I have blasted all the fender mounting hardware and am in the process of priming and painting all the fender bolts and clips.
Old Mar 29, 2022 | 01:20 PM
I saw ur question about when to wire the harness. Its easiest to install b4 engine and routing, clamps, etc.
sounds like a clean blazer r/r
Old Mar 30, 2022 | 05:46 AM
mr.vls's Avatar
Yes. I agree with installing the harness before the engine. Since I had the core support out, I installed the Y-Pipe and the starter on the engine before installation. But, during installation I ran into clearance issues with the engine mounts and had to remove the Y-Pipe and Starter. in order to get the engine installed. Luckily. I had a friend on hand to help guide the engine into the engine bay.
Old Mar 30, 2022 | 07:16 AM
Nice! How much have you gotten crossed off the list?
Wonder how error is doing on his and his alpha...
Old Mar 30, 2022 | 08:28 AM
Now would be a good time to slip an LS motor in that 2wd.. but i see its 2 late. Enjoy the freshness 4 sure
85 s10 blazer
350/350 hp. Naturally aspirated. Fun to drive
