Green 2001 4x4
2001 Olive Green pictures by Chevy33pics - Photobucket
This one got a new lower intake gasket. After installing gasket and changing the milky oil out with used oil and seafoam twice, I filled it a third time and it is smoking white out the tail pipe. I'm still not certain as to the problem due to the seafoaming. The exhaust smells of raw fuel badly. I checked the fuel pressure and it is holding fine. I found the check valve on the exhaust for the secondary air injection bad. I'm waiting on new check valves and I've already got the new 90 degree rubber boots. After I get these parts on I can address the smoking issue. What would be the best way to test for a bad head gasket or cracked head? Pressurize the radiator and check the spark plugs for wetness or leak down test?
I'm getting an Equus 3150 Innova ABS + Professional CanOBD2 Diagnostic Code Scanner for OBDII Vehicles soon. Anyone recommend these?
How long did the water sit in the oil? It's possible it caused rust in the cylinders/bearings and now the gaps are off or it's getting blowby from the rings not being seated properly anymore. Or any number of other things could be happening, valve seats/valves have rust/corrosion on them, spark plugs fouled from water in the cylinders, etc. etc.
I bought this one from a dealer that purchased it at auction. He drove it home and it let go in the yard a couple of days later while he was just moving it to get to another vehicle. I went over to his house to purchase it. He drove it up on the dolly and it was not smoking. There was no water in the radiator then. I suspect a bad gasket or cracked head. I've got a set of reworked 2001 heads already so it is no big deal.
