Jimmy Build
I plan on putting a lift on my blazer this summer, its the 4 door 4x4. I only want 5-6 inches but not as a whole lift, I plan on doing the 2 or 3 inch body lift and a 3 inch suspension lift. I know you can do up to 3 inches with new torsion bar keys, but it also puts stress on components such as the ball joints and CV shafts. I think I have 2 options for the suspension lift. 1.) get the 2.5 rough country kit or 2.) buy torsion keys from eBay ($50) and I already have shackles and get ball joint spacers to reduce the wear on them (the top ones anyway).
Which one should I do? If all else fails I'll just do the 2-3 inch body lift and maybe do a torsion crank. Point is will the ball joint spacers substitute for the new control arms from the actual kit? I know I will have to get new shocks, just trying to compare prices and save a little bit
Sounds like a plan, check PJ's build. He has picked up about 7 inches overall. Good luck. https://blazerforum.com/forum/builds...s-james-66431/
Confuused69
Mar 17, 2010 08:14 PM
