Lift kit/tires help.
i am 18 and ive been working on and building a 2000 Chevy Blazer 4x4. i am looking to buy some tires and rims from a buddy. the rims are 15 inches, and width 11.5 inches. the tires are 32's. how much lift would i need for clearance. trying to go reasonably cheap.
my bad. im new to this and still figuring out how to reply and do the basic things.
Well, i have 31" tires and i didn't even lift or anything, but to be on the safer side and Cheaper side, body lifts are cheap and also crank your t bars and 2" shackle in the rears. after the T crank get an alignment , and if you do the t bars , except to do ball joints and hubs and cv axles allot
Forget the T bar crank. Set your ride to the correct height. Buy what is correct or nearly so, and dont buy cheap. That screaming deal will cost you in the long run. So it will not really be a screaming deal, will it?
The 1-3 leveling will only be your problem. Not because of the ability to clear the tires, you'll still have some minor trimming that'll need to be done, but most of the problems you'll run in to will be premature wear on your cv joints as well as things like ball joints, etc. The best solution would be a slight tweak to suspension and then a body lift to get you the other 2". You'll still need to trimming/bfh massaging but you won't be running through suspension and front 4wd components as quickly. You should take your time and think through what all you want to do, how high you want to go, end goals. If you think you'll be wanting more lift in the future you might want to just consider saving the money and going with the 6" lift from the start. That should give you the ability to clear 32's without much problem besides frame rubbing without sacrificing the reliability of your suspension/4x4 components.
i would like just enough lift to clear the tires. i really dont want to crazy lift it. A 6' would be fine. where would you recommend to look for those.
