Maine-Work in Progress
Old Mar 2, 2011 | 12:03 PM
Dartanian81's Avatar
Dartanian81 is on a distinguished road
Thanks Oktain.
Well I had planned to make a intro thread of repairing this truck, then I was going to make a build thread of me Modifying the truck.
I guess repairing is building, isn't it?
Old Mar 2, 2011 | 12:29 PM
oktain's Avatar
Yeah I guess it is eh? lol.
I'll move it, it'll keep the continuity flowing. "This is EVERYTHING I did to the truck"
*Moved to Builds*
Old Mar 2, 2011 | 01:22 PM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
if it was just seeping out i would have switched to thicker oil to see if it sloes down to the point where it wasnt a big deal, oil pans are a pain in the *** on 4wd trucks. a lift and proper tools makes the job that much easier.
Maine sucks for custom trucks i've been pulled over at OOB a few times in lowered and bagged trucks
Old Mar 2, 2011 | 02:53 PM
It was leaking pretty bad, I was told by the mechanic I had work on it that the Timing Cover was cracked. Upon inspection I found it wasn't but the seal was dry rotted.
It's a crucial spot because the oil pan gasket and timing cover gasket meet here at the lower front part of the block. I figured this would atleast stop the majority if not all of the drip.
Some mechanics say that you need to lower the pan a couple inches to mate the timing cover gasket, but I haven't seen a reason to.
I'm just gonna put her back together this weekend, RTV it and see exactly what's next to tackle.
Old Mar 7, 2011 | 04:43 PM
So everything went good this weekend, no leaks. However I did find out why they told me I would have to drop the oil pan to replace the timing cover gasket.
I just beveled/cut the very back lip to the timing cover off considering it really doesn't hurt the truck any and that lip doesn't seal anything anyway.
Everything went without a hitch.
This weekend I tackle a Manifold exhaust leak, an O2 sensor and then Hopefully I can begin Upgradeing the truck alittle.
Took it for a ride yesterday, the 4.3 in this truck has alot more "Umph" than I had hoped for. More power than the chevy short bed I had previously owned.
More pics to come.
Old Mar 28, 2011 | 05:42 PM
Cool
Have been very very busy with the truck, was only able to work on it over the weekends since my last post but she is coming along very well.
-New wheels and tires (tracker 2's with cragar 15x7 soft 8's)
-Chrome Intake with home-made intake box
-New sparkplugs/wires (Champions)
-New hood (Taken from a guy on craigslist)
-Touch up paint (Krylon from walmart)
-New o2 sensor (rf)
Working on redoing the exhaust, was thinking about duals single into cat double out with 2 flowmasters and exiting on the sides just after the wheels.
May be up for some advice on that.
Had planned on putting a single welded thrush on, but after I bolted it up and listened I took it off. lol Just not throaty and deep enough. Way to quiet.
Attached Thumbnails Maine-Work in Progress-blazer-1.jpg   Maine-Work in Progress-blazer-2.jpg
Old Apr 3, 2011 | 03:48 PM
Talking
Blazer as it sits here 4/3/11, just before I have some exhaust work done later this week.
Attached Thumbnails Maine-Work in Progress-blazer4.jpg   Maine-Work in Progress-blazer5.jpg
Old Apr 3, 2011 | 04:21 PM
-Things I have done differently from when I began this build.
*Decided the yokohoma Geolanders are not as good as stock Tracker 2's. Based on a 500 mile comparison. Tread wear is much better on the trackers, and traction is noticeably the same on/off road.
*Planned to incorporate an Thrush welded single in/out muffler. Changed my mind after hearing it, to a Flowmaster 1 in/2 out idea. <-- Have to have it farbricated though.
*The stock front speakers surpass even the most expensive of walmart ones. Just make sure they are properly connected. ><
-Things I have learned since I began.
*Cold air intake is a personal must. Filter oil= Bad
*Changeing certain spark plugs on this blazer could ruin your whole day.
*4 Lo in this Blazer just like most rarely work, actuators were made poorly.
*Don't use any OEM replacement parts when it comes to ANY of the Ignition stuff.
*Cleaning the Maf sensor, really doesn't do much. Cleaning the throttle body really does ALOT!
*Throttle body spacers= Bad
*Some aftermarket rims and alittle bit of tlc to a blazer can get you more attention than you may want =)
-Things Left to do possibly do.
*Stubby antenna?
*1.5 Inch hub centric Wheel spacers for the back wheels to bring the stance out even with the front wheels.
*Paint (even though I really like the two tone the way it is.)
*KC Highlites
*Fabricate a better skid plate, because that plastic one with the door with access to the oil filter is a joke.
Thanks for reading!
Old Apr 3, 2011 | 04:37 PM
i would only use a/c delco parts for ignition
Chenzo
Dec 27, 2011 10:47 PM
litterbug
Mar 1, 2011 08:59 AM
redmanj79
May 25, 2010 11:41 AM
beatleb95
May 12, 2010 12:51 AM
ncasey207
Mar 30, 2009 02:17 PM
