-   Builds (https://blazerforum.com/forum/builds-48/)
-   -   (MODEL) 1/4 scale see-through V8 (https://blazerforum.com/forum/builds-48/model-1-4-scale-see-through-v8-53543/)
ohsofly Jan 2, 2011 07:46 PM
Yes, when its cold out I dont get into the garage much, instead I have some other hobbies that I figured a bunch of gear heads might enjoy.
For Christmas I got myself a new hockey stick, and this model engine. The kit was about 65 bucks, and its made by Revell, which are not the best quality models out there... But there is not much else available when you want a see through engine.
This is the kit, the finished product is about a foot long and stands about 10 inches high. I have no idea what kind of engine its a copy of, it says nowhere in the instructions. It doesnt have a chevy pattern for the firing order I can tell you that.
http://sphotos.ak.fbcdn.net/hphotos-..._3733431_n.jpg
These are the paints that I chose for doing a few parts. Krylon for plastics is awesome paint. period.
http://sphotos.ak.fbcdn.net/hphotos-..._7176855_n.jpg
The first step was the main rotating assembly. You can see all the areas where I have sanded off the flash that Revell kits are famous for. That crankshaft is about a dozen lobes that link together, you dont glue them, cause it would be hard to get it dead straight, so they peice together like puzzles to allow it to remain straight and smoother.
http://sphotos.ak.fbcdn.net/hphotos-..._2527210_n.jpg
Here it is with the cylinders attached. You use vegetable oil in all of the working areas, just a film is fing, it also keeps the pistons from scratching the cylinders.
http://sphotos.ak.fbcdn.net/hphotos-..._4653888_n.jpg
These timing gears are thin, so its really tricky to glue the butts on the cracnk and cam so there is no lateral play in order to keep the gears meshing forever, but also trying not to get glue anywhere that it can bond the rotating parts.
http://sphotos.ak.fbcdn.net/hphotos-..._6134368_n.jpg
The heads get the valves installed one at a time, and you have to hold it open by hand until the glue dries, this took me about 2 hours just to install the valves straight. There is small springs on the topside to pull the valves closed. There is oil inside all the parts here, only the black keepers are glue on first to slide the wrist pin through.
http://sphotos.ak.fbcdn.net/hphotos-..._1106391_n.jpg
Here is the bottom side of the head, I am holding cyl 2 valves open so you can see how much they move.
http://sphotos.ak.fbcdn.net/hphotos-..._5091865_n.jpg
This is as far as I have gotten so far since christmas. I have the intake and accessories to paint before I install them, Ill come finish the photolog as I make more progress.
http://sphotos.ak.fbcdn.net/hphotos-..._6135636_n.jpg
mov4x4 Jan 2, 2011 08:36 PM
That's pretty cool I've never seen a clear model engine.
DKSDAD Jan 2, 2011 08:52 PM
Wow, I have not seen one of those kits in a long time.
ohsofly Jan 3, 2011 10:58 PM
Yeah there is alot of kits online that I want to do too. Now that I went to the bank and got myself a VISA I can order them... 31 years without ever having a credit card, figured its OK now that I have had no debts for years.
2000Bansheeboy Jan 3, 2011 11:28 PM
That's really cool! I definitely wanna see the end product there...
old skool luvr Jan 4, 2011 04:18 PM
wow, i haven't seen one of those in probably 10 or 12 years! good score on finding it. and if i remember correctly, it's suposed to be based on the 283.
i'm in the same boat as you Thomas, i like doing the kits during the off season (when i have the chance!) but still need to set up the basement for my son & i.
which is what i'm suposed to be doing this week. :icon_emm:
ohsofly Jan 4, 2011 09:01 PM
I found this one in a local hobby shop while looking for a massive 1000+ pc Lego for my kid brother, he does all the large ones and just leaves em put together for show (or so he says).
No new progress, been playing an awful lot of COD Black Ops latley instead and I lost a valvespring when my hand slipped off while holding the head together... Ive moved everything and still cant find it, going to have to try and find another small one at the hobby shop.
