My 72's "Chevy" Wagoneer
Old May 9, 2013 | 08:14 PM
Irocz327's Avatar
Irocz327 will become famous soon enough
Cool My 72's "Chevy" Wagoneer
So as some of you know I traded the Bravada for a ... Jeep.. BUT... Its really chevy undercover.. 84 K5 Drive train. (6.2 Deisel, 700r4, NP208, Dana 44's on 35's).
Current to do list...
B
uilding a new harness for engine.
Building a new harness & replacing the stock guages for functioning ones & adding acouple.
Building a new harness for the taillights. (Right now only the blinkers & headlights work)
Finishing the linkages for the transfercase.
Finishing the exhaust.
Re-doing the brakelines down by the OP.
cleaning up & re-doing some of the interior.
Minor body patching & Paint.
& That's all before I really get in to modding it.. haha
well that said now comes the picture overload.
Attached Thumbnails My 72's "Chevy" Wagoneer-null_zps11f6afbf.jpg   My 72's "Chevy" Wagoneer-null_zpse5451ed1.jpg   My 72's "Chevy" Wagoneer-null_zpscb2bb9e6.jpg   My 72's "Chevy" Wagoneer-null_zps1a31d1b7.jpg   My 72's "Chevy" Wagoneer-null_zpsecdc0414.jpg
My 72's "Chevy" Wagoneer-null_zps8984b676.jpg   My 72's "Chevy" Wagoneer-null_zps78cccb11.jpg   My 72's "Chevy" Wagoneer-null_zps9862e0a3.jpg   My 72's "Chevy" Wagoneer-null_zpsaac865b3.jpg   My 72's "Chevy" Wagoneer-null_zps17bcd7b4.jpg
My 72's "Chevy" Wagoneer-null_zpsf5fa136f.jpg   My 72's "Chevy" Wagoneer-null_zpsee64e09c.jpg   My 72's "Chevy" Wagoneer-null_zps942fe937.jpg   My 72's "Chevy" Wagoneer-null_zpse1e37696.jpg   My 72's "Chevy" Wagoneer-null_zpsf136a97b.jpg
My 72's "Chevy" Wagoneer-null_zps51fff1fa.jpg   My 72's "Chevy" Wagoneer-null_zps4b09eea6.jpg   My 72's "Chevy" Wagoneer-null_zps2999df0b.jpg   My 72's "Chevy" Wagoneer-null_zps90040e5c.jpg   My 72's "Chevy" Wagoneer-null_zpse0a3603f.jpg
Old May 9, 2013 | 08:24 PM
KM346's Avatar
KM346 will become famous soon enough
Looks like it should be a fun project... definitely unique with the old diesel under the hood.
fix that bent drag link too!
Old May 9, 2013 | 08:38 PM
Irocz327's Avatar
Not gunna lie I never even noticed that until you said something.. I'm new to front solid axle but learning. & I'm hoping to Build something big & Learn awhole lot more.
Old May 9, 2013 | 08:52 PM
rexmburns's Avatar
Super Moderator
This will be fun to watch! Now hurry up no sleep tonight just get to work!!!
Old May 9, 2013 | 09:10 PM
KM346's Avatar
Solid axle stuff is easy... and luckily those waggys have kind of a cult following so there is a great after market for them. check out here if you havent already International Full Size Jeep Association - Powered by vBulletin
also..
Did the PO tell you what they did for a lift? Looks like a SOA conversion in front with the stock springs... and maybe blocks / shackle flip in the rear?
If it has any bump steer it looks like it could use a drop pitman if it doesnt have one already
Old May 9, 2013 | 09:23 PM
Irocz327's Avatar
SOA front w/ rear waggy leafs. Blocks on the rear. I'm not a fan of the blocks but for now they'll have to do until I can afford new lift leaf packs.
As far as the suspension up front goes. its on the back burner.
Right now I wonna get my harnesses all figured out & R&R where needed to clean up the chaos. after that R&R seal/leaks on drivetrain w/ all new fluids in everything.
Then interior/exterior. THEN... suspension fixes and upgrades.. lol
& REX- Man I need to get the 5.4 pulled out of an expedtion this wkend that's been sitting in my garage since feb. so I can have room to get the jeep in while I wait for them to get the parts for the expedition. lol..
Old May 12, 2013 | 05:44 PM
Irocz327's Avatar
So that first project is to tackle the engine harness. Does anyone know where I can find a diagram of the eng harness or at least of injector pump?
Old May 12, 2013 | 06:29 PM
rexazz2's Avatar
not much different than most jeeps, a pile of bastard parts
I was always a little shocked when somebody needed a part and it would the same one used on a GM
That deisel should be able to pull you just about anywhere you what to go
Had a couple company supplied shop trucks with the 6.2 and other than being a bit of a PIA in cold weather they had lots of pep
Old May 21, 2013 | 09:31 PM
Irocz327's Avatar
So haven't gotten a ton done yet, but did manage to get the return line on the heatercore ran & coolant in it. I also got about 90% of my e fan & coolant tank installed. hopefully will be able to finish the mounts & the little bit of wiring this week.
FYI the zip ties were just there temporary until I had time to finish the mount.
Attached Thumbnails My 72's "Chevy" Wagoneer-null_zps7c240d1a.jpg   My 72's "Chevy" Wagoneer-null_zpsb8430ddb.jpg   My 72's "Chevy" Wagoneer-null_zpsa95c0b3c.jpg   My 72's "Chevy" Wagoneer-null_zps5bb3d489.jpg   My 72's "Chevy" Wagoneer-null_zpsddf4bfe8.jpg
Old May 22, 2013 | 09:26 PM
Irocz327's Avatar
SO this is wiring Diagram for my E fan. right now I'm running a dual speed single blade thats about 16ins I had for the bravada but decided to put in the jeep since it needed one for right now. so right now I only have the high hooked up because the low speed is burnt out so I'm gunna order a new motor or add another fan.
until then this is how I wonna wire it up so could you guys spot check me & let me know if it's good. & note the breaker is meant to be distribution block on the fire wall & the relay first off the Ign is goin to be my ign source for any other relays in the eng. compartment.
