My 98 S10 Blazer
15 Attachment(s)
I haven't done too much to it, as I'm still working on it and got to get a title issue straightened out, but this what I got so far.
Interior- Attachment 32632 Attachment 32633 Attachment 32634 Attachment 32635 Attachment 32636 Attachment 32637 Attachment 32638 Since i had aftermarket temp and gas gauge, i figured id customize my existing ones in the cluster. Attachment 32639 Attachment 32640 Glowshift water temp and fuel level gauges, they arent fully wired up, so thats why theyre reading wrong. Attachment 32641 Night Attachment 32642 removed the cassette player, the red thing in the top left corner is the posi-lok cable for the 4wd. Attachment 32643 and made a switch panel Attachment 32644 switches to turn the gauges on the pillar on. Got to give credit to Thogert for DIY l.e.d. interior lights. (link to) https://blazerforum.com/forum/builds...e6/#post492539 Exterior- (more to come) Attachment 32645 Black marker lights, with clear lense. Attachment 32646 painted the bow tie. |
good work on the lighting.
looks like its coming together pretty well. |
yeah very nice on the lighting man...This is the color I plan to go with..only difference will be is Im doing white leds on the overhead consoles...
Thanks guys.
And yeah, the blue is a little dim. So if you need light to find somethin . It's a little bit harder than normal, thought about doin some white in the 4 Seperate light or just the 2 in the front. Not sure, I still like it all blue tho. |
Nice job, id like to get one of those gauge mounts like you have
Looking good.
Thanks thog.
And talkin about the pillar pod, Brian? I got mine from autometer. It was pretty expensive But I didn't want to get a universal one and it not fit. It only fit 95 to 02. Not sure what you have tho. |
Looks good nice clean work and well thought out on the switches facing different directions. I like the little dudes on the gauges best though!!
Yeah I haven't seen anything quite like te gauges. I thought it was pretty cool.
So now I've run in to another problem. When I turn the key on. My rpms jump up to 1k and my speedo just up to about 10 mph? So when I'm driving aroundy gauges are off. Any ideas? |
87 k5, its cool none the less. :D
Originally Posted by MikeTastic
(Post 545062)
So now I've run in to another problem. When I turn the key on. My rpms jump up to 1k and my speedo just up to about 10 mph? So when I'm driving aroundy gauges are off. Any ideas? So I took the cluster fuse out but th gauges still jump up. I have no clue. Any ideas? |
i would check the under the hood fuse box, look at the wires and see if any are burnt or just lose, also check the ignition switch wires and wires inbetween the door. more than likely it is just a wire *i hope so, my last blazer all the wires burned...sad day.
