My (On Going) Blazer Project
1 Attachment(s)
Well, here it is. My blazer just starting out in the stages of transformation. This last weekend I put a BDS long add-a-leaf in the rear and cranked the torsion bars up in the front. Attached is a picture of before (top) and after (bottom) the add-a-leaf was put in. Sorry if it is hard to tell, but there is a couple inch difference in the way that it sits. And those are stock tires (235/70R15) on there now. Now that is done, I need to put lower ball joints in and a new idler arm before I get an alignment. The bad part about that is, I am now busy working on the farm and will not have time for those until this winter probably. (Besides I could use a new set of tires anyway :icon_angel: ) And also I am going to put a hitch on this winter, along with a flowmaster (I hope). And then to top it all off, it needs a brush guard to finish off the look I think.
The worst part is, all of this will probably take a while...as the title states it is an on going project :icon_shrug: |
I can def see a difference there, nice job!
Originally Posted by CraigSnedeker
(Post 466400)
Good Luck! :icon_wink:
Dumb question.. Did that add a leaf give that extra height? |
Originally Posted by FsTFwRd
(Post 466772)
Dumb question.. Did that add a leaf give that extra height? EDIT: Well, my worst fears have been realized. Got under the Blazer today after changing the oil to grease the front end and found out that after the tbar crank my cv joint boots have slipped enough to throw grease everywhere...great...well I guess that comes with the territory EDIT 2.0: Finally got my Blazer back and I am so happy!!! New CV axles and the Blazer wasn't actually lowered much in the front, which I may actually lower it a little more just to make sure that the CV fiasco doesn't happen again... |
Well not that anyone cares since it is such a little mod, yesterday I installed side window vents on the blazer and ordered a Curt hitch. Hope the hitch will be in early enough today for me to pick up! Can't believe I waited so long for things that are so simple...
Just got the hitch put in today. Whoever said about a 30 min installation apparently hasn't worked on a 13 year old vehicle that has been through NW Ohio winters for all that time and that the stock bolts had loctite put on them....uh huh....a half and hour....yeah sure, whatever they say, but I'm glad I did it. Pics if someone wants them of the vents and/or hitch even though it is pretty obvious what they look like
You can take those clamps off the cv boots, and replace them with screw tight hose clamps, the hold tighter than the cv clamps do and they wont pop off as easy.
Window vents are always one of my first mods. I find they suck cig smoke out much better. I always color match mine. |
Originally Posted by ohsofly
(Post 512473)
1 Attachment(s)
So after some time away, a few different things have been done to my Blazer. Yesterday a buddy of mine helped me take the pin striping off the fenders and doors and also most of my bumper stickers (except the 4x4 in the back side windows). I also put new headlight bulbs in from headlightbulbs.com. I got to drive a little with them last night, but do not have any pics of how they look now. I may end up getting pics of that tonight. While I had the grille out to replace the bulbs, I also took my bowtie out and painted it black. In the picture, the blue tint of my new bulbs are faintly visible from that angle. More pictures to come
https://blazerforum.com/forum/attach...ine=1437316717 |
