my K5's evolution
I took the 2 vehicles i enjoy the most and merged them into 1 capable off road rig that will now go damn near anywhere i aim it...
I Love the old Willys jeeps but they just aint stout enough for what I wanted and I Love the K5 Blazer but it was Too bulky to fit in really tight spots... soo... i just combined the 2.. by using the body off my Willys i had for parts and using everything els from my K5.. My blazer when i first bought it a loooooooooonnnnng time ago... http://i141.photobucket.com/albums/r...ictures024.jpg Then soon after i got it I jacked it up 10" with 38" TSL's and it stayed like this for many years http://i141.photobucket.com/albums/r...ys/blaze-1.jpg http://i141.photobucket.com/albums/r...7-24-09005.jpg http://i141.photobucket.com/albums/r...chstump010.jpg My '53 willys CJ-3B high hood. http://i141.photobucket.com/albums/r...1024091335.jpg CJ-3B on K5 Chasis http://i141.photobucket.com/albums/r...1025091638.jpg then stretching the body 34", the hood 9" and chopping the frame off all the way to the leaf springs i was able to make it fit.. as u can see i used all components of the K5.. steering column ,pedals, seats,4x4 shifter.. except now it has no more computer crap... http://i141.photobucket.com/albums/r...Picture117.jpg http://i141.photobucket.com/albums/r...p/712950d0.jpg I removed everything involving gasoline which included my TBI system, tank , lines, and everything els under the hood that became useless at that time... I run straight propane now... I DID keep the throttle body and installed a simple 1 wire HEI distributor... i just modified the throttle body with a restrictor plate that i made to just direct the propane to the butterflys and nowhere els... http://i141.photobucket.com/albums/r...p/097dfb8d.jpg here is the "Impco 425 tophat that creates the air/fuel mixture .. like a carb for propane http://i141.photobucket.com/albums/r...p/64ccb95f.jpg the converter (left) and this is the check valve (right) ... the coverter circulates the hot water through it to convert the LPG into a gas form... takes it from "high pressure" to "low pressure".. http://i141.photobucket.com/albums/r...p/4177172b.jpg then began the details http://i141.photobucket.com/albums/r...p/5b98b43b.jpg http://i141.photobucket.com/albums/r...p/2731bac9.jpg http://i141.photobucket.com/albums/r...p/f3ce3835.jpg then the end result http://i141.photobucket.com/albums/r...p/5e07226b.jpg http://i141.photobucket.com/albums/r...p/edbb1cbf.jpg http://i141.photobucket.com/albums/r...p/6e28dcf1.jpg now all i lack to completeion is 1 ton chevy axles .. shackle flip in rear.. hydro steering and a winch... I did jump ALOT of documentation to try to keep this as brief as possible.. also... i do have a Painless wiring system for an '88 K5 TBI system WITH computer if anyone is interested... |
That's bad ass I wish I had a k5 but I just got a 97 blazer
| All times are GMT -5. The time now is 07:26 AM. |
