Originally Posted by Captain Hook
(Post 624391)
If front chassis ride height is out of spec, premature idler arm wear is only the beginning of your problems with suspension and steering parts.
If you can get enough lift with a body lift kit, and keep chassis ride height within specs, steering & suspension components will operate as designed and maintenance costs will be significantly reduced.
Nice build! If you're looking for a good 10" sub still, check out the Kenwood Excelon. I have a 10" Excelon sub and its a shallow mount sub, so it has a smaller motor on the back and it still hits hard!
Originally Posted by BigBlackBlazer
(Post 624493)
go for a SA-8
update
8 Attachment(s)
Its been awhile so i thought i would update;
truck hit 360,000kms today, still surprises people when they see it, and see how clean the interior is for its mileage and vintage. Replaced the thermostat and flushed out the dex-cool with some prestone green, as it was running a little hot. bought some fluid for the t-case and went to change the oil and cracked the fill plug , and litterally 2-3 litres of atf came out the fill plug, so have to change that t-case input seal.. Did some wheeling last weekend and found out fast that its going to need some more lift as it was rubbing the fenders and body quite a bit.. Had some time to clean it up a bit today, so i took some pictures down at the lake this evening. https://blazerforum.com/forum/attach...ine=1404709220 https://blazerforum.com/forum/attach...ine=1404709220 https://blazerforum.com/forum/attach...ine=1404709220 https://blazerforum.com/forum/attach...ine=1404709220 |
