Project: Just Another v8 blazer
Old Feb 2, 2012 | 12:02 PM
  #71
Phil's Avatar
Seeing pics of an Edelbrock carb makes me miss my 84 Sierra.
Old Feb 2, 2012 | 01:47 PM
  #72
FER86GTI's Avatar
FER86GTI is on a distinguished road
i dislike my edelbrock lol. i kinda want to put a quadrajet on it.
Old Feb 2, 2012 | 02:18 PM
  #73
InsanePyro's Avatar
InsanePyro is on a distinguished road
What color paint is that (the grey)? I mean the actual name of it
Also where does the temp gauge connect to? I'm thinking of putting one in mine seeing as the one in the cluster is shot
Old Feb 2, 2012 | 05:40 PM
  #74
FER86GTI's Avatar
gray? you talking about the flat black on the blazer?
also my coolant temp gauge goes in the motor under the exhaust manifolds on the driver side. it may be different for a 2.8 or 4.3.
Old Feb 3, 2012 | 04:04 AM
  #75
InsanePyro's Avatar
Looks rather gray to me
Old Feb 3, 2012 | 07:01 AM
  #76
TheRandom1's Avatar
Probably because it's dirty in that picture... looks flat black to me when it's clean.
Old Feb 3, 2012 | 10:27 AM
  #77
FER86GTI's Avatar
it is, the top is factory gloss black, the top of the side is flat, and the bottom of the side is a goofy rough black paint with gold flake.
Old Feb 11, 2012 | 03:43 AM
  #78
FER86GTI's Avatar
going to finish my custom gauge cluster tomorrow
also, i have a question. i'm going to need new front brakes pretty soon. just wondering if there is something out there thats better. not aftermarket cause i'm sure aftermarket is expensive. is newer blazer or camaro calipers and rotors an better? and would they fit?
i figured since i'll be buying new front brakes i might as well see if anything is a direct swap.
Old Feb 12, 2012 | 05:02 AM
  #79
FER86GTI's Avatar
finished my gauge cluster.
went from this
and $50 later, it went to this.
Old Feb 28, 2012 | 01:00 PM
  #80
FER86GTI's Avatar
so i went to a junkyard and found a muncie 5speed, the junkyard only wanted $123 for the trans. the trans is good too, the junkyard wants $123 for any trans. SCORE!
also got this steering wheel for $12
and cut the seat brackets and re welded them for the seat to sit low. helped me out ALOT.
idk why i took this pic, but im posting it anyway.
also my edelsuck 600 took a poop on me, so i got a quadrajunk from a big block cadillac from the same junk yard i got the steering wheel and trans. only paid $20 for the carb and it works awesome. way better then my 600.
my rear end is leaking gear lube from the passenger side axle seal.
so i'm going to get a rear end with disc brakes from a late 90's bravada for $81 from the same junk yard. i was looking at exploder rear ends in the junkyard. they have 6 of them. but the swap looks like it may take longer then the time i have to fix my rear end.
