Project Ohio Blaze
Old Nov 3, 2009 | 10:05 AM
96chevblazer's Avatar
yeah lol it works, its aluminum tape used on duct working
Old Nov 3, 2009 | 10:13 AM
Sisk's Avatar
You should have done what I did...slap a cherry bomb in there and ditch the tail pipe all together
Old Nov 3, 2009 | 02:12 PM
I'm planning on it, or maybe a super 44 not sure yet
Old Nov 3, 2009 | 03:01 PM
Sisk's Avatar
I hear the super 44 is awesome. Gives a better sound. The cherry bomb is it's cheaper cousin though . I couldn't afford the super 44, so i went with the CB
Old Nov 3, 2009 | 04:33 PM
opps wrong thing can a mod delete this post please thanks!
Old Nov 3, 2009 | 04:52 PM
Here is how I installed my power inverter. It works great I have played PlayStation in my truck with it! It cost about 40 bucks at Walmart.
1) Remove the lower part of the dash on the drivers side. (Above the Gas and Brake peddles
2) Inside the engine compartment (above where the brake peddle would be on the inside) Look for three indents, that form a triangle. This is where the hole should go (inside the triangle)
In the engine compartment
Inside the truck, you can see one of the small dents of the triangle
3) Drill the hole large enough for your wires
4) Run your wires and don't forget a fuse I used a add-a-fuse deal.
5) Hook to battery, I chose these clips because it is simple and I can unhook it and not fear a drained battery.
6) Now for the wires inside the truck, I ran the under the plastic in the door jams right under my drivers seat
7) I ran a master switch in my center console.
8) Make sure all soldered connections are good and taped well, then hook it up and try it!
Oh ya about the Tint, I Said screw it, it's too hard to do and the temps are now too cold do it, It would freeze to the window over night lol
Old Nov 10, 2009 | 04:57 PM
Okay i got around to cutting the pipe and fitting the tip, Cutting the pipe and putting the tip on made it a little bit louder here is a youtube vid of it
http://www.youtube.com/watch?v=R_VC9f1FZFY
Here is the stock pipe
You can see where i am gonna cut, it is where the first black line is
Here is the tip, I got it for $8 bucks at Auto Zone
Here is the pipe with the tip before cutting
Here's how much I cut off
And here is final product!
Old Nov 10, 2009 | 06:05 PM
CraigSnedeker's Avatar
looks kewl :P
Old Nov 10, 2009 | 06:26 PM
Originally Posted by CraigSnedeker
looks kewl :P
Thanks
Old Nov 19, 2009 | 03:07 PM
Okay so I haven't really posted pcis of my truck yet so here they are
Traxxas is the brand of R/C cars I race, that decal is soon to be a bf.com decal!
Pretty Nice for my first truck!
