Project: Sharlet (aka Risen Phoenix)
as most of you know i had an engine fire a few months ago and sadly im just now being able to start the rebuild.
heres the after math of said fire... https://blazerforum.com/forum/genera...setback-56087/ what ive gotten done thus far: changed plugs and charred plugwires fixed fuelline ((hopefully)) Whats left to fix: serpentine belt wiring harness ((thats going to be fun:icon_no: )) |
2 Attachment(s)
got the grille off the other day...love the way it looks but doesnt rly fit right around the headlights...so i have 3 options and i want input....
1) keep the grille and work around the fitting issue 2) go to an OE year-correct grille (( :icon_no: )) 3) custom grille...possibly hide lights behind grille? before & after below... |
update:
replaced the serpentine today.....one step closer to blazin' around whats left... wiring harness :icon_errrr: |
Good luck with your rebuild.
thanks....i think the wiring is going to be the worst part...monitarily and physically...not looking forward to that at all
yes... wiring is a PAIN lol just set a whole day aside and take your time
since theres just a little of the wiring burnt up..im thinking about just buying the connections and just cut wiring to fit instead of dishing out 250$ for the complete harness
any opinions on the afore mentioned grill issue anyone?...all input welcome...
1 Attachment(s)
had a thought and 'shopped this...dont know how possible it might be...but what do yall think?
Originally Posted by Maestro
(Post 425994)
You going for the Close Encounters look when you're rolling up behind someone? :icon_razz: |
lol didnt think about that at first...but i like it haha
just gotta find different color lights and a keyboard now! haha
thought of a theme for Sharlet....thinking a Black Widow theme...((IE 8 lights in front for "eyes" and a red hourglass on the back window....any thoughts or suggestions?
okay got a choice here...
1) go for the whole wiring harness for around 250$ 2) cut and splice the charred wires 3) use electrical tape and patch it...or use Liquid Tape my vote is for the 2nd one...any advice? |
Replace the burn wiring and have at'er with shrink tubing. Just make sure you use the right guage of wiring and your soldering is good lol. It'll be time consuming but you'll save lots of cash.
Oh, and *Name changed as per PM request* |
If it were me, I would go to the junkyard and pull a used wiring harness and install it and be done.
$250? that must be for a new harness. Don't cut n splice, you are just asking for further troubles, or fires. |
2 Attachment(s)
after months of looking and scouring everywhere to find parts i finally found something....
this project is finally on the road to recovery new 2.8L wires and all and an upgrade to a 5sp. tranny |
hurray for fuel economy!
started taking the charred wiring out today....going to continue tomorrow with the gutting and possibly transplanting of wiring and TBI
updates will be coming in as progress is made |
Good choice.
got nearly everything hooked back up...just a few more odds and ends w the harness and a fuel line/hose and probly some brake work and she should be good to go!
tried to move and reposition it the other day and something shocking happend....the rear wheels locked up and would only turn backwards....
transfer case and tranny were both in neutral we're thinking it could possibly be the previous owner who possibly put the shoes on backwards... |
okay i got her all patched up...but gettin no fuel to the engine...theres a few loose wires that i dont know where they go...any help would be welcomed
Well,where is the loose wires? any connectors on them? colors? When you had the fire you may have blow a fuse or 2. check em if you have not. Get a volt meter and make sure the pumps getting power. check at the relay too.
4 Attachment(s)
heres what they look like.... im suspecting the pink/black and brown one has something to do with the fuel pump...but not sure
Hey man, the second pic looks like it belongs on the back of the alternator.
If you have a look at my build, I appear to have the same grill that you have, I hate how mine fits and will be replacing it. I put red lights behind mine, and I think I wanna do a phantom grill on it. |
alright yall...i figured out where one of the wires goes...the 3rd and 4th pic....it hooks into the transmission :icon_doh:
aslo got the fuel pump off so ill try to see whats wrong with it...possibly replace it **EDIT** tested fuel pump...it works just fine..... noticed that the new harness has 2 relays on the drivers fender while the old has 3...so thinking that may now be the issue |
alright yall...finally figured out the problem......lack of grounds for the wires :icon_doh: so shes just about running now
updated list of things to do to get her roadworthy...
brakes timing(?) zipties for the wires tires and thats it....just to get roadworthy (i hope) only after that ill start the mods :icon_playing: |
Glad to hear you got her running
she sounds nice whats with it starting on third shot ?
she hasnt run in quite a while...so proply just a few cobwebs that had to get flushed out
oh ok but i love the way she sounds
thanks...the previous owner cut out the cat in the exhaust...but it has a slight exhaust leak...but ill get that patched up eventually
i got a small leak by the cat what can i do the patch it ? put a clamp ?
umm...clamp maybe....or weld it....possibly JB weld? not sure if that would stand up to the heat tho
yea when my cat and muffler went up on fire i sorta bent the y pipe a little so its bent a little by the lip and its sounds sorta bad when you 1st start it but goes away when the motors hot
yeah id just try to find the hole and probly just weld it or try to straighten it out and sinch it down
alright i decided to resurrect this project, got some drastic ideas in store...
for starters, gota get 'er road worthy... * fix the locked up E-brake cable * battery *fix the super rich-ness so im not tasting gas and not fogging mosquitos MODZ *1965 C10 front end conversion *relocate gas door behind tail light *((eventually)) V8 *paint ((maybe)) MODZ *suicide doors with mirrors as handles *chop top |
