got nearly everything hooked back up...just a few more odds and ends w the harness and a fuel line/hose and probly some brake work and she should be good to go!
tried to move and reposition it the other day and something shocking happend....the rear wheels locked up and would only turn backwards....
transfer case and tranny were both in neutral we're thinking it could possibly be the previous owner who possibly put the shoes on backwards... |
okay i got her all patched up...but gettin no fuel to the engine...theres a few loose wires that i dont know where they go...any help would be welcomed
Well,where is the loose wires? any connectors on them? colors? When you had the fire you may have blow a fuse or 2. check em if you have not. Get a volt meter and make sure the pumps getting power. check at the relay too.
4 Attachment(s)
heres what they look like.... im suspecting the pink/black and brown one has something to do with the fuel pump...but not sure
Hey man, the second pic looks like it belongs on the back of the alternator.
If you have a look at my build, I appear to have the same grill that you have, I hate how mine fits and will be replacing it. I put red lights behind mine, and I think I wanna do a phantom grill on it. |
alright yall...i figured out where one of the wires goes...the 3rd and 4th pic....it hooks into the transmission :icon_doh:
aslo got the fuel pump off so ill try to see whats wrong with it...possibly replace it **EDIT** tested fuel pump...it works just fine..... noticed that the new harness has 2 relays on the drivers fender while the old has 3...so thinking that may now be the issue |
alright yall...finally figured out the problem......lack of grounds for the wires :icon_doh: so shes just about running now
updated list of things to do to get her roadworthy...
brakes timing(?) zipties for the wires tires and thats it....just to get roadworthy (i hope) only after that ill start the mods :icon_playing: |
Glad to hear you got her running
