-   Builds (https://blazerforum.com/forum/builds-48/)
-   -   Rough Country 2.5" Lift!!!! (https://blazerforum.com/forum/builds-48/rough-country-2-5-lift-64416/)
Mike98Blazer Nov 24, 2011 06:54 PM
Originally Posted by neo71665 (Post 477068)
Guys its only designed as a 2 inch lift, its not a 5 inch cradle that drops the front diff way down. There isn't much room to drop the front diff before you are rubbing the axles. The little bit will help but still imho worthless when the sfa kit isn't much more and you get way more from it.
I built my sfa kit and only have $50 in it. Add 100 for a dana 30 and 100 for springs if you have the stuff its much cheaper. The limited market of parts for a series that is out of production is gonna keep the prices high and the companies willing to design parts for us limited. Sometimes you just gotta take what ya can get or forge your own path.
Question for ya, I've been thinking about doin a sas, what did you do about abs? If you got rid of it how did you eliminate it from throwing a code (In PA if there's any active codes in the computer it fails inspection no matter what it's for)
neo71665 Nov 24, 2011 10:28 PM
87 bud, no abs on mine. Heck we dont have fender laws or sniff tests. I only have to keep my headlights below like 54 inches or something like that.
Over on s10forum they have the measurements for a ring that allows you to run the s-series bearing hubs. This allows you to keep your abs and wheel bolt pattern.
S10 unit bearing to XJ Knuckle adapter ring - S-10 Forum
Other than that you just need somebody to remove the abs from the ecu. If ya want more infor on sas swaps on a friendly forum I suggest checking out s10extremist.org. Most of the same guys as s10forum but the maturity is higher over there.
Ne s10 blazer Nov 25, 2011 03:29 PM
Originally Posted by rhino420 (Post 476301)
would i still be able to tuck 31's under the back? Right now im running stock 235/7515 but i really want to run 31x10.5 15 in the back and the front and I know I wont have a problem in the front because I'm getting fiberglass front fenders and hood similar to this s-10
below ( this one is way more advanced then what im doing)
http://i279.photobucket.com/albums/k...t/IMG_0677.jpg
I have been looking all over for fenders like that where are you going to get them from?
rhino420 Nov 25, 2011 04:39 PM
Prerunners - Woolworth Motorsports
this place has them but There is a local place around me that im getting mine done at. Ill see if they can ship and get back to you.
Benedict1337 Nov 25, 2011 05:01 PM
you can fit 31's in the back at stock height
neo71665 Nov 25, 2011 06:23 PM
Never delt with one with a saggy butt have ya, lol
xgiovannix12 Nov 25, 2011 06:30 PM
lol saggy butt sounds weird
Xb-lineblazerX Nov 28, 2011 05:55 PM
any other in-expensive lifts you guys know of? sounds like this new RC one isn't so reliable. suggestions for different lifts that aren't $100,000.. or details about how you made your own??? (shackles, brackets etc..)
Mike98Blazer Nov 28, 2011 06:50 PM
Parts Bin - Auto Parts and Accessories Catalog - p64cl221pa 1992 chevrolet blazer torsion_key perf_accessories - 1992 Chevrolet Blazer
82-04 Chevy S10 / Blazer 2" Lift Shackles
Performance Accessories 152 3" Body Lift Chevy S Series Blazer / GMC Jimmy 98-03
Warning: Without a diff drop torsion keys or torsion cranking CAN wear out CV's fast....... You've been informed.
neo71665 Nov 28, 2011 08:36 PM
Without the drop brackets you can crank the factory front end (Limited to 1.5 inches) and do the same exact job as the keys. Save your money.
Shackles are 2 inche for every one inch of lift.
Ex. Say the stock shackles are 3 inches center to center of the holes making a set that is 5 inches center to center will gain one inch.
