Originally Posted by 1997 Gmc Jimmy
(Post 473642)
did the add-a-leaf come with the kit?
& as far as the frame rub goes remember its only 2.5" lift! I have a 2" on the truck right now w/ the t-bars turned up BUT not cranked all the way & 2" shackles & I have rub on the frame at full turn or pulling in to an incline drive way or such. I hoped the extra half inch might cure that but as you've said your rubbing I'm guessing not.. Don't fuss over it'll come 2nd nature to know where to stop so you don't rub real quick! lol.. It's weird for me to drive my fiancee's AWD Vibe & to be able to turn past that point in it w/ out hearing any rubbin. But then again that thing turns on a dime compared to a blazer lol if you tweaked the T-bars after you already got an alignment then yes you do have to get another alignment done. |
As far as the rubbing goes, my stock zr2 rubbs at full lock it's not a big deal.
Originally Posted by Irocz327
(Post 473817)
No. When I ordered my RC 2" lift way back in june it was an option thru 4wheelingplus.com for it and the steering stabilizer at extra cost. I bought it because the Bravada sags to the bump stops almost whenever I pull anything w/ it so I wanted alittle extra support in the rear end for hauling.
Originally Posted by El Diablo793
(Post 473897)
I called rough country and they said that the blazer they have does not rub at all. He said that I needed to adjust the steering stop, but I was out for a joyride today with it after the speedometer vibration and tire balancing and it went well anyways as far as turning goes. I am going to put on a steering stabilizer though because she is kind of squirrely at the moment. Rides somewhat stiff too...
(Post 473897)
I pray that none of you have the problems that I am having. CV on passenger side is throwing grease. =[
(Post 473935)
we need picture updates from the people with the lifts
Both my cvs ate throwing grease kts because the clamps ar old on the boots and the tbar crank puts them at a diff angle than stock.
Originally Posted by Ne s10 blazer
(Post 474040)
| All times are GMT -5. The time now is 02:49 AM. |
