Detailing Discuss detailing your Blazer within.
How to remove door moulding/badge without ruining paint?
Old Nov 13, 2010 | 10:19 PM
reapher's Avatar
reapher is on a distinguished road
Default How to remove door moulding/badge without ruining paint?
I have a 2001 blazer, unfortunately the previous owner tried to put in a door from a 95 or something and it's got a different moulding like in the picture (NOT MY BLAZER) here as well as an LS badge when it's an LT blazer . Since I am putting the correct things back on over the paint behind them, the paint doesn't have to be pristine but I don't wanna risk scraping the paint and starting rust since the whole car and especially this door was recently painted. Just didnt have these pieces available at the time of painting to install. Is there some special fluid that will deactivate the double sided tape without hurting the paint or is a razor blade the only option? I'm thinking I should have just bought the whole door off a 2001 in the junkyard because this door had no sound deadening, a whole different latch which 2 of the 3 electronic plugs can't plug, and the whole wire harness wasnt compatible - initially. This door is still the only give-away that the car has been in an accident, it's almost comical when the one door strip is not the right one one side says LS and one says LT and on the interior... different handle and cup, I need to chop up the inner door a bit to put the right handle in this door.
This door......... I'd be pretty satisfied to pass it off as being stock and just not having the irregularities on the outside of the door as well as inside
Attached Thumbnails How to remove door moulding/badge without ruining paint?-1992_chevrolet_blazer_2_dr_sport_4wd_suv-pic-42759.jpg
Old Nov 14, 2010 | 12:48 AM
UberFail's Avatar
UberFail is on a distinguished road
DENTAL FLOSS!!!!!!!!!!!!!!!!!!!!!!!!! that stuff will cut thru double sided tape so long as its not retardedly thin, fishing line will work too... i debaged my car with it without any hindrance to the paint itself. the residue that's left over from the other half of the tape can be removed with anything like gas or specialty products such as "Goo Gone".... if u go the gas route MAKE sure its on a rag and you clean the area u just used it on thoroughly afterwards.
Old Nov 14, 2010 | 01:03 AM
69chevelle's Avatar
69chevelle is on a distinguished road
we use to actually use white gas on the new RV's to clean the black markings off the sides, there isnt as many addatives.(camping fuel)
Old Nov 22, 2010 | 06:22 PM
Moores12345's Avatar
Moores12345 is on a distinguished road
8LB fishing line works wonders. Breaks off every once in a while but just cut a new piece of line and keep cutting at the backing of the badge/emblem. As for the left over residue and tape behind it left on your vehicle. I just used paint thinner and worked from there.
Old Nov 23, 2011 | 09:48 AM
Tmac98's Avatar
Tmac98 is on a distinguished road
If i use dental floss will i be able to use the badges again? I want to paint them black.
George Del Giorno
Jul 26, 2024 05:39 AM
Aj10116
May 27, 2014 08:56 AM
Rogue
Detailing
16
Jul 10, 2010 05:05 PM
Baja Blazer 85
Jul 13, 2009 03:11 PM
megtom2
Oct 27, 2007 11:16 PM
