Detailing Discuss detailing your Blazer within.
Keeping tire lettering white
Old Jun 20, 2007 | 11:53 AM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
Default Keeping tire lettering white
I recently ran across an article about keeping your white letters white so I'll share some of the content in paraphrase form.
Most tires, after a few years of age, start to fade or yellow. Tires that are used every day tend to pick up raod grime and look dingy and dirty. There are a few steps you can take to whiten them. So here are some tips about different things to use and what they do to the rubber.
[ul][*]-Whitening by a strong bleach will fade the black rubber on the rest of the tire, don't use it. [*]-Degreasers (greased lightning, etc)work well but after many times of use it will start to dry rot the rubber because it is a chemical that works against petroleum. **[*]-Laquer thinner is by far the best at whitening, but it must be applied only to the letters themselves and without scrubbing.**[*]-Mineral spirits works with no majorside effects to the rubber.[*]-Bar soap is a good thing to use, but requires a lot of scrubbing. **[*]-Tire bleach (bleche white, tire clean, etc) is great at cleaning the tire, but not whitening the letters.[*]-Shoe cleaner/glass cleaner or anything with mild amounts of ammonia work very well.**[*]-Never use Varsol.[/ul]
**Care should be taken around aluminum and alloy wheels and all painted rims.
Old Jun 20, 2007 | 06:59 PM
rabbit0102030's Avatar
rabbit0102030 is an unknown quantity at this point
Default RE: Keeping tire lettering white
Interesting tips. When I had white walls on my blaze, I had a white tire paint pen that I used to keep the lettering white.
Old Jun 20, 2007 | 07:03 PM
davtak's Avatar
I use Armor All Tire Foam and let it sit for like 5 minutes and do a little scribbing then I use Armor All Extreme Tire Shine and it lasts for a while. I even use the Extreme Tire Shine on the rims too. It works pretty well.
Old Jun 20, 2007 | 08:28 PM
EuroGoldLS's Avatar
I have a paint pen too, I used it on the Goodyears I had and it looked crappy, I think the pen might have been slightly dry though...
Old Jun 20, 2007 | 08:33 PM
Yeah, I had that problem after I had the pen for a while, I figured the same that it was getting too dry. Worked good when it was newer though, and I was too lazy to do all that scrubbing!
Old Jun 20, 2007 | 08:47 PM
EuroGoldLS's Avatar
If you put laquer thinner or mineral spirits on it, all you do is apply it with a rag with no scrubbing at all.
Old Jun 21, 2007 | 05:09 AM
TheBrettster's Avatar
TheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond repute
On limos we used Westleys bleche white and that stuff worked great even for the letters, we also used minerial spirits but i dont know if its safe for the tire.
Old Jun 21, 2007 | 11:18 AM
FFJustin99Chevy's Avatar
FFJustin99Chevy is an unknown quantity at this point
I just have a really stiff bristled brush. After I finish washing it, I use the excesssuds and scrub the lettering. Doesn't take much scrubbing if your brush is good size and bristles are super stiff. Guaranteed safe......it's just soap and water.
Old Jun 21, 2007 | 03:34 PM
viper4559's Avatar
viper4559 is an unknown quantity at this point
I used a stiffer brush once, and I started chipping my white off......
Old Jun 21, 2007 | 10:33 PM
Yeah that was the thing I couldn't stand about scrubbing my tires.
