Detailing Discuss detailing your Blazer within.
Restoring the black..........
Old Dec 7, 2005 | 02:16 PM
Bocomo's Avatar
Bocomo is an unknown quantity at this point
Default Restoring the black..........
When I was carelessly waxing the Blazer I got some was on the black door handles and stuff. It just doesn't seem to clean up no matter what I try.
Anybody have any good suggestions?
Bocomo
Old Dec 7, 2005 | 08:17 PM
Bojib's Avatar
Bojib is an unknown quantity at this point
Default RE: Restoring the black..........
I got a good stiff bristled brush that works for me when that happens. Kind of like an over sized toothbrush, of course a toothbrush could work just as well on it too.
Old Dec 9, 2005 | 04:10 PM
Canadian88's Avatar
Canadian88 is an unknown quantity at this point
A good cleaner might be all you need. I use SimpleGreen on pretty much everything i need to clean on my truck (except the body) I use it for bugs, tar, etc. Should work for you.
Old Dec 9, 2005 | 06:28 PM
Bocomo's Avatar
Default Thanks, I'll give those ideas a try.
Seems I've tried some "normal" washing procedures. Maybe I need some extra elbow grease when I'm trying to clean it. I'll try this weekend if it gets above 35'F.
Old Dec 9, 2005 | 10:03 PM
Default RE: Thanks, I'll give those ideas a try.
You could try a normal wax remover (solvent), but it would tend to dull the plastic. You would then need to use a product like Mother's Back-to-Black.
You could also try a bristle brush and some dawn dish soap. Dawn has a tendancy to strip wax off of your paint, so it should remove the wax from your trim as well and the reason why I say get a bristle brush is to thuroughly clean the rough surface, better than you could with a cloth.
Old Dec 10, 2005 | 12:21 AM
Canadian88's Avatar
No matter what you use, simply green is the ****. You should pick up a bottle next time you're at walmart or something. You'll begin to see all the uses for it even around the house.
Old Jul 3, 2006 | 08:40 AM
TheBrettster's Avatar
TheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond reputeTheBrettster has a reputation beyond repute
Clean the trim with simple green then go in with some mothers "back 2 black" you wont be sorry.
Old Jul 24, 2006 | 02:33 PM
TN_TrailBlazer's Avatar
TN_TrailBlazer is an unknown quantity at this point
I just bought a 2000 Trailbalzer. The flat black trim on the back corners were faded, oxidised and just looked work. I tried the mothers "Back-to-Black"......WOW WOW WOW. I did one side and not the other to see if i could appreciate the difference. It was amazing. Good luck with your clean up.
Old Aug 3, 2006 | 04:27 PM
Dory's Avatar
Retired Super Moderator
Dory is a jewel in the roughDory is a jewel in the roughDory is a jewel in the rough
its amazing how old posts never die here... hehehehe
Old Nov 15, 2006 | 12:29 AM
Bocomo's Avatar
Default On that note..........
I asked my wife to pick up some Simple Green. She did, although she bought some lemon scented yellow Simple Green. The next time we were in WalMart together I showed what I MEANT when I sad Simple Green, the stuff in automotive---not generally house cleaning.
I haven't used Mother's Back to Black yet, but the lemon scented Simple Green did work pretty well. And it does do a good job for other cleaning purposes, too.
Just trying to keep this thread going...........
