2.8l to a 350 motor swap
Old Feb 21, 2010 | 11:59 PM
Kerias's Avatar
Kerias is on a distinguished road
look id love to keep the tranny i love my 4x4 im just a bit confused lol i kno the 2.8 700r4 wont bolt up to a 350! ok so that means new tranny? and was said that the 4x4 may not be able to handle the torque of a 350? (if the tranny i currently have can bolt up?)
Old Feb 22, 2010 | 12:22 AM
old skool luvr's Avatar
no, no, no. it was said that the front diff isn't the stongest, and having the power of a 350 in your truck will definately blow that (and your rear one) given enough beatings.
seriously, why not just swap in a 4.3, since you can have a wiring harness that'll just go right in without any custom work to it? it would make your life (and the swap) so much easier.
Old Feb 22, 2010 | 02:46 PM
abig84's Avatar
Heck I used to snap cv joints in the front of my 85 with a 2.8 only running on 5cyl. The rear should be fine. I did a v8 swap in a 95 and that's all I did was beat that truck
Old Feb 22, 2010 | 05:12 PM
neo71665's Avatar
The front end and rear end will hold up as long as you aint out trying to tear it up. Find a 700r4 out of a s-series with a 4.3 and 4x4. It will have the correct bolt pattern for the small block and all of your stuff will bolt to it.
Old Feb 23, 2010 | 07:52 PM
Kerias's Avatar
ok i talked to jegs and asked about a tranny bellhousing adapter from a 2.8 to a 350 and he gave me this http://www.jegs.com/i/JEGS/555/60170/10002/-1 or here's the part number 555-60170 i need to know if this will for sure work? and just a recap what exactly do i need to do to just get the motor in and driveing?
Old Feb 23, 2010 | 09:23 PM
neo71665's Avatar
Just get a 700r4 out of a 4x4 s-10 with a 4.3 or a fullsize truck, use your t-case, bolt the 350 to it, and run it.
FYI that plate is to convert a chevy 90 degree to a buick, olds, pontiac (BOP) pattern not to a 60 degree.
Old Feb 23, 2010 | 10:17 PM
86Blazer4x4's Avatar
86Blazer4x4 is an unknown quantity at this point
if your still worried about there being too much power(which i believe there is no such thing) you could always do a 3.4L swap. you can use stock everything. and you do get a good increase in power about 200hp with heads from another 3.4L. i dont know which set off the top of my head. the only major thing you would do is swap out the injectors in the TBI with ones from a 4.3L so it wont run lean.
Old Feb 24, 2010 | 12:59 AM
Blazin_Jason's Avatar
You'll need a different oil pan as well to clear the front diff and give enough capacity.
PROJECT85K5
Jun 23, 2013 02:40 PM
tech180
Feb 2, 2013 10:23 AM
shotnva777
Oct 11, 2011 10:24 AM
worlok
Mar 12, 2009 08:50 AM
1989blazed
Mar 31, 2008 09:48 PM
