RE: 350 swap Pics
ORIGINAL: Zygoat jason thats some nice stuff, how much did that lift cost ya, the fan is all powdercoated? it looks great. Mojo you should think about an electric fan. It will free up a little power too and moves plenty of air. I am going to install mine on low speed and try that out first. If that's not enough then I'll just rewire it on high. I've read that almost everyone runs em on low normally, and on high with the A/C on. I'm removing my a/c though. Also will hardwire in a bypass switch in the cab to turn on high if needed. |
RE: 350 swap Pics
hmm i guess i will have to go snag me a taurus fan from the junkyard soon then
if mine idles to long it starts to get warm but then again i only have a small single e-fan and a small engine fan btw mine's an 85 with 31's and a 350 5speed 4wd |
RE: 350 swap Pics
really!?
got any pics? |
RE: 350 swap Pics
Well mojoman I test fitted my engine today after work. All I have to say is take your time. You might want to get a hammer and do all the clearance mods that the JTR manual says to. Luckily since I have a 3" BL I didn't need to do any of that stuff, and it's still a tight fit. You will be glad that you took your front end apart as well. Once I get my front end back together like the suspension parts so that I can put the truck back on it's wheels, I will implant the new heart of my blazer. =)
RE: 350 swap Pics
a 3" BL? sry to sound like an idiot but wat is that?
but ya me and me dad will do it and he has a pretty good variety of hammers to help it fit :D |
RE: 350 swap Pics
Body lift.
RE: 350 swap Pics
ahh gotcha
so wat are your doing with the wire harness in your truck? like there so many wires that dont need to be used right |
RE: 350 swap Pics
Hah ya I know. I left them all there for the time being. It looks worse than it is. Once things start going back together it will clean up. Any remaining wires will be removed. My truck was carbed though. Yours?
Gross http://www.blazinjason.com/mess.jpg |
RE: 350 swap Pics
mine was TBI and the compartment looks like a mess
http://i69.photobucket.com/albums/i4...03-07_1303.jpg http://i69.photobucket.com/albums/i4...03-07_1304.jpg http://i69.photobucket.com/albums/i4...03-07_1305.jpg |
RE: 350 swap Pics
Well I removed my AC. I will either modify the heater box for a little more room or get a heater box from a non AC truck. Also removed the cruise control. I have 80' of new purple wire loom, and will probably order 80' more just in case. I have 20' each in 4 different sizes. I want to keep it as clean as possible and will be very basic. Are you gonna run a carb too?
