4x4 conversion
I have a 95 4-door with 2-wheel drive and was would be involved in coverting it to 4-wheel drive.
Any help appreciated, thanks. |
RE: 4x4 conversion
Welcome to the site.
Tranny- Convert your 2wdr to 4wdr by swapping the output shaft and tailhousing to the t-case adapter, or replace teh tranny with a 4x4 unit. T-case- you'll need one. Plus you will need to modify or maove your current tranny cross brace. Plus you will need a front driveshaft and shorten your rear driveshaft. I wouldn't even mess with a factory S10 front axle set-up. I would instead cut all the IFS stuff out and install a solid front axle. Check out this site for more info. http://www.s10extremist.org/ |
RE: 4x4 conversion
the tranny output shaft is different lengths from the 2wd to the 4wd so an entire new tranny would be in order.....also alot of other stuff...you'd be better off selling your 2wd and buying a 4wd
RE: 4x4 conversion
ORIGINAL: smdepew1976 you'd be better off selling your 2wd and buying a 4wd |
RE: 4x4 conversion
right unless he's going to SAS it
RE: 4x4 conversion
Sounds like were on the same page.
RE: 4x4 conversion
I converted mine to a 2wd. I removed the front driveshaft. I want to see if I can get 1/2 mpg increase. 40 miles so far and no difference.
RE: 4x4 conversion
Ummm. the front dirveshaft doesn't spin when the truck is in 2wdr. If you want to gain mpg, you need to remove the center chunk in the front axle. :D
